Build system answers are more reliable from Janet, but my unskilled
suggestion would be to add the OS class to the assignment. Since
this is a 'system' library, perhaps the right statement would be:
PROD_SYS_LIBS_RTEMS += bspExt
Janet -- can you add bspExt to the base/configure/os/
CONFIG.Common.RTEMS-mvmeXXXX files so that folks won't need to add
the above line to their application makefiles?
On May 2, 2007, at 4:11 PM, John Sinclair wrote:
I guess I was missing this piece. I had to manually copy the
library (could have soft-linked it) and add
USR_LIBS += bspExt
to the makefile. But then, since make is being instructed (why?) to
also build the system on the host (linux-x86), this library
was missing for the linux build. I created a dummy one using ar and
the build finally succeeded.
Is this the "correct" way to do EPICS with RTEMS or do I somehow
have things half-configured?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- EPICS on RTEMS John Sinclair
- Re: EPICS on RTEMS Eric Norum
- Re: EPICS on RTEMS John Sinclair
Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
<2007>
2025
2026
EPICS on RTEMS Heinrich du Toit
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
