1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: JCA Library usage
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 11 May 2007 13:02:06 -0400
On May 11, 2007, at 10:45 , David Dudley wrote:
All is fine and good to be able to use this, -except-, in the case of
distributing an application, or as an applet, there is no way to provide
a location of where to get the 'JCALibrary.properties' file. Can the
capability of providing a location (preferably being able to use a URL
Link as well) be added to 'getInstance' (or should I do it?)?
Actually I think you can already put something like this in your code:
System.setProperty("com.cosylab.epics.caj.CAJContext.addr_list",
... your value ...);
System.setProperty ("com.cosylab.epics.caj.CAJContext.auto_addr_list",
... "YES" or "NO" ...);
Meaning:
All that's usually loaded from the JCALibrary.properties
can be initialized in your code.
So you can hardcode it in your application,
or have your application read that info from
some jar file location as you suggest and copy it to System.setProperty().
Also, is there a way to create a channel and then 'add' a connection
Listener as a separate function?
Maybe not. But not a show stopper:
Just always create the channel with your 'Forwarding Listener',
and then those later listeners register with your 'Forwarding Listener'.
Of course you'll have to implement that 'Forwarding Listener'.
Or a way to close a channel?
There is a
   Channel.destroy()
as well as a
   Channel.dispose().
I don't know the difference, but I use the 'destroy()' call and
that works nicely.
Beware, though:
If you have listeners, the 'JNI' version will completely remove the
channel and all listener information,
while the 'CAJ' version might still invoke your listener
with another value update, where the status is actually
indicating "channel was destroyed",
so it makes some sense, it's just that most people who've used
the JNI (C/C++) based CA client lib might not expect another
event from the destroyed channel.
-Kay
Re: JCA Library usage David Dudley
Prev: Re: JCA Library usage J. Lewis Muir
Next: Re: JCA Library usage David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
