1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: JCA Library usage
To: <[email protected]>
Date: Fri, 11 May 2007 13:13:53 -0500
This is useful as a workaround, however if I want to use this to drive
an applet on a WEB page, for instance, I don't want to have to hardcode
into the applet the address of where to get data.  I'd much rather
create a properties file on the server, and somehow tell the package
that it needs to get it's properties from a particular stream.
That way, if I have a page with 50 applets on it, I could pass a
parameter to the applet as to where to get the properties from.
Just a thought-
David
>>> Kay-Uwe Kasemir <[email protected]> 5/11/2007 12:02 PM >>>
On May 11, 2007, at 10:45 , David Dudley wrote:
> All is fine and good to be able to use this, -except-, in the case
of
> distributing an application, or as an applet, there is no way to
> provide
> a location of where to get the 'JCALibrary.properties' file.  Can
the
> capability of providing a location (preferably being able to use a
URL
> Link as well) be added to 'getInstance' (or should I do it?)?
Actually I think you can already put something like this in your code:
      System.setProperty("com.cosylab.epics.caj.CAJContext.addr_list",
	                        ... your value ...);
      System.setProperty
("com.cosylab.epics.caj.CAJContext.auto_addr_list",
	                        ... "YES" or  "NO" ...);
Meaning:
All that's usually loaded from the JCALibrary.properties
can be initialized in your code.
So you can hardcode it in your application,
or have your application read that info from
some jar file location as you suggest and copy it to
System.setProperty().
> Also, is there a way to create a channel and then 'add' a connection
> Listener as a separate function?
Maybe not. But not a show stopper:
Just always create the channel with your 'Forwarding Listener',
and then those later listeners register with your 'Forwarding
Listener'.
Of course you'll have to implement that 'Forwarding Listener'.
> Or a way to close a channel?
There is a
    Channel.destroy()
as well as a
    Channel.dispose().
I don't know the difference, but I use the 'destroy()' call and
that works nicely.
Beware, though:
If you have listeners, the 'JNI' version will completely remove the
channel and all listener information,
while the 'CAJ' version might still invoke your listener
with another value update, where the status is actually
indicating "channel was destroyed",
so it makes some sense, it's just that most people who've used
the JNI (C/C++) based CA client lib might not expect another
event from the destroyed channel.
-Kay
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
JCA Library usage David Dudley
Re: JCA Library usage Kay-Uwe Kasemir
Prev: Re: JCA Library usage Kay-Uwe Kasemir
Next: Re: Accessing Date and Time information Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Asyn Delay Robert Emery
