1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Accessing Date and Time information
Cc: [email protected]
Date: Fri, 11 May 2007 21:34:50 +0200
Hi Andrew,
Andrew Johnson wrote:
Yes, there's a stringin device support delivered as part of Base since R3.14.5 that you can give an strftime string to. Eg:
record(stringin, "$(user)now")
    field(DESC, "Current time and date")
    field(DTYP, "Soft Timestamp")
    field(INP, "@%Y-%m-%d %H:%M:%S.%03f")
If you need the fields as integers rather than strings you can use one stringin record per field and rely on the numeric conversions built into the database links to convert the VAL field of each record into the appropriate integer -- not wildly efficient, but functional.
As the VxWorks strftime() does not support "%s" (seconds since the epoch), is there another reasonable way to get this number from the timestamp of a record into the value field of the same (or another) record?
Ralph
Re: Accessing Date and Time information Andrew Johnson
Accessing Date and Time information David Dudley
Prev: Re: JCA Library usage David Dudley
Next: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Rodney R. Porter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Accessing Date and Time information Andrew Johnson
Next: Re: Accessing Date and Time information Andrew Johnson
