1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAJ Options
To: <[email protected]>
Date: Tue, 15 May 2007 13:18:34 -0500
After putting a bunch more comments in my Applet file, what I find is that the call to JCALibrary.getInstance() completes successfully, but the call to jca.createContext() fails.
My code is:
â-------------------------
			try
				URL codebase=this.getCodeBase();
				String host=codebase.getHost();
				// Get the JCALibrary instance
				jca=JCALibrary.getInstance();
				System.out.println("Instance initialization passed");
				System.setProperty("com.cosylab.epics.caj.CAJContext.addr_list",host);
				System.setProperty("com.cosylab.epics.caj.CAJContext.auto_addr_list","false");
				// Create a thread safe context with default configuration values
				ctxt=jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
				System.out.println("Context creation passed");
			catch(Exception ex)
				System.err.println("Initialization failed for " + dpm.dataSource+":\n" + ex);
				System.exit(1);
The console outputs:
Initialization failed for Util1:Tot:KW:
java.security.AccessControlException: access denied (java.util.PropertyPermission com.cosylab.epics.caj.CAJContext.addr_list write)
java.security.AccessControlException: access denied (java.lang.RuntimePermission exitVM.1)
	at java.security.AccessControlContext.checkPermission(Unknown Source)
	at java.security.AccessController.checkPermission(Unknown Source)
	at java.lang.SecurityManager.checkPermission(Unknown Source)
	at java.lang.SecurityManager.checkExit(Unknown Source)
	at java.lang.Runtime.exit(Unknown Source)
	at java.lang.System.exit(Unknown Source)
	at Applet1.initDPM(Applet1.java:279)
	at Applet1.init(Applet1.java:61)
	at sun.applet.AppletPanel.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Line 279 (the error line) is the line number of the System.exit(1) function call.
ideas??
David Dudley
>>> Kay-Uwe Kasemir <[email protected]> 5/15/2007 12:13 PM >>>
On May 15, 2007, at 12:16 , David Dudley wrote:
> OK, all you JCA and CAJ people, here's a problem for you-
> I'm setting up JCA/CAJ to run through an applet.  How do I prevent
> them
> from *attempting* to find the JCALibrary.properties file?
> When an applet tries to find the file, it creates an access security
> exception, since Applets, by nature, can't access the underlying file
> system.
> I tried doing System.setProperty commands to set
> 'com.cosylab.epics.caj.CAJContext' to values before the createContext,
> but the moment that createContext is accessed, I get an error.
Interesting.
In jca-2.3.0/src/core/gov/aps/jca/JCALibrary.java
there's this code:
     try {
         InputStream is = JCALibrary.class.getResourceAsStream
( "JCALibrary.properties" );
         if (is == null)
             throw new RuntimeException("resource not found.");
         _builtinProperties.load( is );
     } catch( Throwable ressourceEx ) {
       System.out.println( "Unable to load default configuration....);
I would think the worst that can happen is a println,
and your System.setProperty calls would actually win.
But maybe that attempt to read a file does worse things
to an applet, something that the catch() doesn't catch?
I'd try to change that code section somewhat to see
what's happening in your case.
-Kay
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: CAJ Options J. Lewis Muir
CAJ Options David Dudley
Prev: CAJ Options David Dudley
Next: Re: CAJ Options J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
