David Dudley wrote:
After putting a bunch more comments in my Applet file, what I find is that the call to JCALibrary.getInstance() completes successfully, but the call to jca.createContext() fails.
My code is:
try
URL codebase=this.getCodeBase();
String host=codebase.getHost();
// Get the JCALibrary instance
jca=JCALibrary.getInstance();
System.out.println("Instance initialization passed");
System.setProperty("com.cosylab.epics.caj.CAJContext.addr_list",host);
System.setProperty("com.cosylab.epics.caj.CAJContext.auto_addr_list","false");
// Create a thread safe context with default configuration values
ctxt=jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
System.out.println("Context creation passed");
catch(Exception ex)
System.err.println("Initialization failed for " + dpm.dataSource+":\n" + ex);
System.exit(1);
The console outputs:
Initialization failed for Util1:Tot:KW:
java.security.AccessControlException: access denied (java.util.PropertyPermission com.cosylab.epics.caj.CAJContext.addr_list write)
java.security.AccessControlException: access denied (java.lang.RuntimePermission exitVM.1)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkExit(Unknown Source)
at java.lang.Runtime.exit(Unknown Source)
at java.lang.System.exit(Unknown Source)
at Applet1.initDPM(Applet1.java:279)
at Applet1.init(Applet1.java:61)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Line 279 (the error line) is the line number of the System.exit(1) function call.
ideas??
David Dudley
Hi, David.
It looks like it might be failing because the applet does not have write
permission to *set* the system property
"com.cosylab.epics.caj.CAJContext.addr_list" in the System.setProperty call.
You could try the approach I suggested earlier to see if it might work
instead:
DefaultConfiguration conf = new DefaultConfiguration("applet");
conf.setAttribute("class", "com.cosylab.epics.caj.CAJContext");
JCALibrary.getInstance().createContext(conf);
-lewis
Kay-Uwe Kasemir <[email protected]> 5/15/2007 12:13 PM >>>
On May 15, 2007, at 12:16 , David Dudley wrote:
OK, all you JCA and CAJ people, here's a problem for you-
I'm setting up JCA/CAJ to run through an applet. How do I prevent
them
from *attempting* to find the JCALibrary.properties file?
When an applet tries to find the file, it creates an access security
exception, since Applets, by nature, can't access the underlying file
system.
I tried doing System.setProperty commands to set
'com.cosylab.epics.caj.CAJContext' to values before the createContext,
but the moment that createContext is accessed, I get an error.
Interesting.
In jca-2.3.0/src/core/gov/aps/jca/JCALibrary.java
there's this code:
try {
InputStream is = JCALibrary.class.getResourceAsStream
( "JCALibrary.properties" );
if (is == null)
throw new RuntimeException("resource not found.");
_builtinProperties.load( is );
} catch( Throwable ressourceEx ) {
System.out.println( "Unable to load default configuration....);
I would think the worst that can happen is a println,
and your System.setProperty calls would actually win.
But maybe that attempt to read a file does worse things
to an applet, something that the catch() doesn't catch?
I'd try to change that code section somewhat to see
what's happening in your case.
-Kay
- CAJ Options David Dudley
- Re: CAJ Options David Dudley
<2007>
2025
2026
<2007>
2025
2026
