I had an include file that wasn't included. Fancy that ;-)
Still, have the following code
â-------------------------------------------
try
URL codebase=this.getCodeBase();
String host=codebase.getHost();
System.out.println("Configuration starting");
DefaultConfiguration conf=new DefaultConfiguration("applet");
System.out.println("Context created");
conf.setAttribute("class","com.cosylab.epics.caj.CAJContext");
System.out.println("Attribute Added");
System.out.println("Instance created");
// Get the JCALibrary instance
jca=JCALibrary.getInstance();
System.out.println("Instance initialization passed");
// System.setProperty("com.cosylab.epics.caj.CAJContext.addr_list",host);
// System.setProperty("com.cosylab.epics.caj.CAJContext.auto_addr_list","false");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.addr_list",host);
conf.setAttribute("com.cosylab.epics.caj.CAJContext.auto_addr_list","false");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.connection_timeout","30.0");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.beacon_period","15.0");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.repeater_port","5065");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.server_port","5064");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.max_array_bytes","16384");
conf.setAttribute("com.cosylab.epics.caj.CAJContext.thread_pool_size","5");
System.out.println("Creating context");
// ctxt=jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
ctxt=jca.createContext(conf);
System.out.println("Context creation passed");
catch(Exception ex)
System.err.println("Initialization failed for " + dpm.dataSource+":\n" + ex + "\n");
System.exit(1);
and it's producing the following error.
Context created
Attribute Added
Instance created
Creating context
Initialization failed for Util1:Tot:KW:
gov.aps.jca.CAException: Unable to create context
java.security.AccessControlException: access denied (java.lang.RuntimePermission exitVM.1)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkExit(Unknown Source)
at java.lang.Runtime.exit(Unknown Source)
at java.lang.System.exit(Unknown Source)
at Applet1.initDPM(Applet1.java:295)
at Applet1.init(Applet1.java:62)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
By looking at the code, you can see that it gets down to doing the actual createContext call before failing.
No, I'm not running it in the Sun Applet viewer. Believe it or not, things were working fine in the viewer, and it would even read the properties file successfully. Turns out the problem wasn't the properties file at all, but this one next in the code.
I'm using Eclipse to create a .jar file, and I've got a WEB page that invokes the applet in IE.
Curious and curiouser...
David Dudley
>>> "J. Lewis Muir" <[email protected]> 5/15/2007 3:40 PM >>>
David Dudley wrote:
> For some reason I get a "cannot find symbol" for the line
> Can't seem to get past that line.
Hi, David.
Are you getting that error at compile time or run time? What is
producing that error? Is there a stack trace? Are you running your
applet with the Sun JDK's appletviewer program?
-lewis
>>>> "J. Lewis Muir" <[email protected]> 5/15/2007 1:35 PM >>>
> David Dudley wrote:
>> After putting a bunch more comments in my Applet file, what I find is that the call to JCALibrary.getInstance() completes successfully, but the call to jca.createContext() fails.
>> My code is:
>> try
>> // Create a thread safe context with default configuration values
>> catch(Exception ex)
>> System.err.println("Initialization failed for " + dpm.dataSource+":\n" + ex);
>> System.exit(1);
>> The console outputs:
>> java.security.AccessControlException: access denied (java.util.PropertyPermission com.cosylab.epics.caj.CAJContext.addr_list write)
>> at Applet1.initDPM(Applet1.java:279)
>> at Applet1.init(Applet1.java:61)
>> Line 279 (the error line) is the line number of the System.exit(1) function call.
>> ideas??
>> David Dudley
> Hi, David.
> It looks like it might be failing because the applet does not have write
> permission to *set* the system property
> "com.cosylab.epics.caj.CAJContext.addr_list" in the System.setProperty call.
> You could try the approach I suggested earlier to see if it might work
> instead:
> DefaultConfiguration conf = new DefaultConfiguration("applet");
> conf.setAttribute("class", "com.cosylab.epics.caj.CAJContext");
> JCALibrary.getInstance().createContext(conf);
> -lewis
>>>>> Kay-Uwe Kasemir <[email protected]> 5/15/2007 12:13 PM >>>
>> On May 15, 2007, at 12:16 , David Dudley wrote:
>>> OK, all you JCA and CAJ people, here's a problem for you-
>>> I'm setting up JCA/CAJ to run through an applet. How do I prevent
>>> them
>>> from *attempting* to find the JCALibrary.properties file?
>>> When an applet tries to find the file, it creates an access security
>>> exception, since Applets, by nature, can't access the underlying file
>>> system.
>>> I tried doing System.setProperty commands to set
>>> 'com.cosylab.epics.caj.CAJContext' to values before the createContext,
>>> but the moment that createContext is accessed, I get an error.
>> Interesting.
>> In jca-2.3.0/src/core/gov/aps/jca/JCALibrary.java
>> there's this code:
>> try {
>> InputStream is = JCALibrary.class.getResourceAsStream
>> ( "JCALibrary.properties" );
>> if (is == null)
>> throw new RuntimeException("resource not found.");
>> _builtinProperties.load( is );
>> } catch( Throwable ressourceEx ) {
>> System.out.println( "Unable to load default configuration....);
>> I would think the worst that can happen is a println,
>> and your System.setProperty calls would actually win.
>> But maybe that attempt to read a file does worse things
>> to an applet, something that the catch() doesn't catch?
>> I'd try to change that code section somewhat to see
>> what's happening in your case.
>> -Kay
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- Re: CAJ Options J. Lewis Muir
- CAJ Options David Dudley
- Re: CAJ Options David Dudley
<2007>
2025
2026
<2007>
2025
2026
