1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: wanted: rule to build products with own CFLAGS inside single Makefile
To: [email protected]
Date: Wed, 30 May 2007 12:22:13 -0700 (PDT)
Hello,
I have an RF phase and amplitude detection application which needs to
be built slightly differently for each RF station. I want to keep the
code as one single app and build multiple products. I need each product
to have its own CFLAGS definition to pick up its correct code.
Here is the Makefile I have so far, including the two options I have tried,
but which do not work.
TOP=../..
include $(TOP)/configure/CONFIG-uC5282
include $(EPICS_BASE)/configure/CONFIG_GDB
#  ADD MACRO DEFINITIONS AFTER THIS LINE
DO_STRIP_OBJ=NO
# build an ioc application
#PROD_HOST = padMonitor
PROD_IOC_RTEMS += pad-gen
PROD_IOC_RTEMS += pad-ref
PROD_IOC_RTEMS += pad-lsr
PROD_IOC_RTEMS += pad-l1xkly
PROD_IOC_RTEMS += pad-genkly
PROD_IOC_RTEMS += pad-bph
# pad.dbd will be created and installed
DBD += pad.dbd
pad_DBD += base.dbd
pad_DBD += devPad.dbd
pad_DBD += drvPad.dbd
USR_CFLAGS_RTEMS += -D__rtems
# CHOOSE 1! depending on which instance of the code you want to run:
# Use PAD_GEN for RFGun1, RFGun2, L0A, L0B, TCav, L1S, L2Tcav # Use PAD_REF for RF distribution
# Use PAD_LSR for laser
# Use PAD_L1X_KLY for L1X and L1X Kly (yes, really)
# Use PAD_KLY for RFGun Kly, L0A Kly, L0B Kly, TCav Kly, L1S Kly L2TCav Kly
# Use PAD_BPH for Beam Phase Cavity 1 and 2 Combo
# 5/30/7: option 1. this doesn't work. None of these flags get used because
# <product>_CFLAGS_* is not interpreted
pad-gen_CFLAGS_RTEMS += -DPAD_GEN
pad-ref_CFLAGS_RTEMS += -DPAD_REF
pad-lsr_CFLAGS_RTEMS += -DPAD_LSR
pad-l1xkly_CFLAGS_RTEMS += -DPAD_L1XKLY
pad-kly_CFLAGS_RTEMS += -DPAD_KLY
pad-bph_CFLAGS_RTEMS += -DPAD_BPH
# 5/30/7: option 2. this doesn't work because PROD_IOC_RTEMS is a list of all the
# targets so every test matches! #ifeq ($(findstring gen,$(PROD_IOC_RTEMS)),gen)
#USR_CFLAGS += -DPAD_GEN
#endif
#ifeq ($(findstring ref,$(PROD_IOC_RTEMS)),ref)
#USR_CFLAGS += -DPAD_REF
#endif
#ifeq ($(findstring lsr,$(PROD_IOC_RTEMS)),lsr)
#USR_CFLAGS += -DPAD_LSR
#endif
#ifeq ($(findstring l1xkly,$(PROD_IOC_RTEMS)),l1xkly)
#USR_CFLAGS += -DPAD_L1X_KLY
#endif
#ifeq ($(findstring genkly,$(PROD_IOC_RTEMS)),genkly)
#USR_CFLAGS += -DPAD_KLY
#endif
#ifeq ($(findstring bph,$(PROD_IOC_RTEMS)),bph)
#USR_CFLAGS += -DPAD_BPH
#endif
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
pad-gen_SRCS += pad_registerRecordDeviceDriver.cpp
# Repeat as pad-gen_SRCS for pad-ref_SRCS, pad-lsr_SRCS, ...
# Add locally compiled object code
pad-gen_SRCS += drvPad.c
pad-gen_SRCS += devAiPad.c
pad-gen_SRCS += devAiCnstPad.c
pad-gen_SRCS += devWaveformPad.c
pad-gen_SRCS += devLonginPad.c
pad-gen_SRCS += devLongoutPad.c
pad-gen_SRCS += devBoPad.c
pad-gen_SRCS += devMbboPad.c
# SNCSEQ stuff here (.st and libs)
# OTHER LIBS here
# HOST PRODUCTS here
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
debug:
	@echo targets are $(PROD_IOC_RTEMS)
thank-you,
Dayle Kotturi                                            [email protected]
LINAC Coherent Light Source                             office 650-926-4923
Stanford Linear Accelerator Center                         fax 650-926-4778
Re: wanted: rule to build products with own CFLAGS inside single Makefile Andrew Johnson
Prev: Re: help-serial driver for linux Dirk Zimoch
Next: Re: wanted: rule to build products with own CFLAGS inside single Makefile Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
