1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: waveform binary init
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Mon, 2 Jul 2007 07:44:48 -0500
Heinrich,
If your array is less than 40 characters you can use the asyn record.  If you use "ASCII" mode, then it does the following before it writes the AOUT array:
        /* ASCII output mode */
        /* Translate escape sequences */
        nwrite = dbTranslateEscape(pasynRecPvt->outbuff, pasynRec->aout);
So it will translate escape characters.  In your example if you set AOUT to "\000\001\008" and set TMOD="Write" then this will write that array to the device.  Remember to set the terminator to an empty string if the device does not need a terminator.
If you use the waveform record it will not do dbTranslateEscape, so you need to find another way to get binary data into the waveform.
The asyn EPICS waveform record device support does NOT read the current value into an output record at iocInit.
From: [email protected] on behalf of Heinrich du Toit
Sent: Mon 7/2/2007 1:11 AM
To: TechTalk EPICS
Subject: waveform binary init
Hi
I have an octet device. (asyn driver)
It sends commands to some hardware. Now if I send a certain sequence of
chars to the device I can perform some stuff. e.g. reset the device. Or
set a certain mode. - things that will correspond to buttons on the user
interface.
So I like to setup a waveform record with the necessary data inside as
default. And then only trigger the PROC field so that the data be
written to the device.
My only question is - how do I specify this binary data to the waveform?
for example how do I setup a waveform with CHAR data: 00 01 08  or
something like that?
does the waveform things also read once at start up with asyn? even if
it is a write only command?
thanks
-Heinrich
waveform binary init Heinrich du Toit
Prev: RE: GPIB Ethernet gateway recommendation Pearson, MR (Matthew)
Next: tds3000 Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: waveform binary init Dirk Zimoch
