1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV save and restore tool sought
To: Thomas Birke <[email protected]>
Cc: [email protected]
Date: Tue, 31 Jul 2007 12:00:13 -0700
On Fri, 2007-06-29 at 16:55 +0200, Thomas Birke wrote:
> The warm-reboot save-and-restore is realized with the IOC-based version
> of autosave as it comes with the synApps package.
I am currently investigating warm reboot.
As such, I am currently investigating autosave and may move away from
that feature implementation in the driver.
My questions are:
* Is autosave the mainstream tool? i.e. the bumpless utility used by
most of you? I heard at SLAC, they are using channel watcher.
http://www.slac.stanford.edu/comp/unix/package/epics/extensions/ChannelWatcher/index.html
Is there anything else that you recommend I look at?
* What are autosave's and your recommended software's limitations? what
happens in a case of a ioc crash? can backup files be corrupted? Are
backups saved in files or database? Are files the most simple and
reliable architecture? what are the disadvantage/advantages of a
distributed database? central database?
* What are the disadvantages/advantages of ioc-based backup utility
versus others designed as ca-client?
I read "The current version of Save/Restore (sr), also known as Bumpless
Reboot, may be interfering with normal IOC operations due to the large
number of file writes." How much of a problem is that, really?
* Is there a SIMPLE way to generate a req/request file on the fly for
backup? I have "dynamic" ioc, where the names of records may change
between reboots, or some records may just disappear. Do you have each
time to reconfigure the backup request file? Although I believe this
should be required for a general backup utility, why should it for a
bumpless reboot utility?
Is it possible to generate a req file at ioc startup that save all the
"live" records with name's ending with *O or *AO, etc. ( a dbgrep to a
file can help, but the backup utility needs to reread its config files )
* What happens if the backup utility is looking for a record that
doesn't exist? Is backup still ongoing? Does it significantly increase
the traffic load on the network?
* Is log-on-change possible for individual output records? I heard this
is not the forte of autosave, but I may be wrong.
* What if there are no values previously saved on the particular ioc.
What is the default value? The one in db file? Is it possible to
import/copy backup data?
* Although I am mostly interested in bumpless reboot, are there
utilities that do bumpless reboot in a very similar way they do regular
backup? I am currently using sddscasr (casr in sdds files ), but am
reacquainting myself with casr and burt. Should I look at those or are
they deprecated? Should I look at any other applications?
* etc.
Emmanuel
Re: PV save and restore tool sought Kay-Uwe Kasemir
Re: PV save and restore tool sought Tim Mooney
Re: PV save and restore tool sought Emmanuel Mayssat
Re: PV save and restore tool sought Carl Lionberger
PV save and restore tool sought Rock, Judith E.
Re: PV save and restore tool sought Thomas Birke
Prev: Embedded EPICS IOC David DeBonis
Next: Re: Embedded EPICS IOC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV save and restore tool sought Thomas Birke
Next: Re: PV save and restore tool sought Kay-Uwe Kasemir
