1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV save and restore tool sought
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Tue, 31 Jul 2007 15:08:26 -0700
We had a version of autosave at LBNL that looked at characters stuck in the end of the record description file at boot time, using the static library, to find out what records should be saved. It restored according to what records were in the save file. That was really convenient in many cases, for example the characters (which just were a sort of regular expression for the fields to be saved) could be put in the template files and no matter how you expanded the templates it would work.
We used this for the SNS front end but no one seemed comfortable with it and the APS autosave was outstripping it on file checking/handling (they had a common ancestor...), so while I was at SNS I switched away from the LBNL version. My last act of maintenance was to strip out the search and make it into a thing you could call in the startup file to generate the request file before running whatever file based autosave you like. As far as I know it has never been seriously used. It should still be in the SNS cvs repository. The old LBNL autosave (i think only 3.13 compatible) is called "bumpless", "autoBReq" is the 3.13 version of the req file writer, and "autoBReq314" a 3.14 version.
Kay could dig it out, I think
Carl
bumpless                epics/supTop/front_end/bumpless
autoBReq                epics/supTop/autoBReq
autoBReq314             epics314/supTop/autoBReq
Emmanuel Mayssat wrote:
* Is there a SIMPLE way to generate a req/request file on the fly for backup? I have "dynamic" ioc, where the names of records may change between reboots, or some records may just disappear. Do you have each time to reconfigure the backup request file? Although I believe this should be required for a general backup utility, why should it for a bumpless reboot utility? Is it possible to generate a req file at ioc startup that save all the "live" records with name's ending with *O or *AO, etc. ( a dbgrep to a file can help, but the backup utility needs to reread its config files )
Emmanuel
Carl Lionberger 510 486 7503
Software Developer, Engineering Division
Lawrence Berkeley National Laboratory
Re: PV save and restore tool sought (correction) Carl Lionberger
Record info nodes? Re: PV save and restore tool sought Kay-Uwe Kasemir
PV save and restore tool sought Rock, Judith E.
Re: PV save and restore tool sought Thomas Birke
Re: PV save and restore tool sought Emmanuel Mayssat
Prev: Re: PV save and restore tool sought Emmanuel Mayssat
Next: Re: PV save and restore tool sought (correction) Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
