1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Record info nodes? Re: PV save and restore tool sought
To: tech talk <[email protected]>
Date: Wed, 01 Aug 2007 09:20:43 -0400
On Jul 31, 2007, at 18:08 , Carl Lionberger wrote:
We had a version of autosave at LBNL that looked at characters stuck in the end of the record description file at boot time, using the static library, to find out what records should be saved.
Yes, one can use the DESC field to add additional information, like in this case instructions for autosave. I've also used it to provide additional parameters to an analog input device module. But that's of course somewhat of a hack.
I think there is now a better way to do this,
because the Database files support adding non-field
meta information to record instances,
beyond just the values of record fields.
I don't remember the exact syntax, even though Andrew
has pointed it out several times.
I think it's called "info node",
and could be used to add parameters for
autosave, archiving, ... anything to record instances.
Of course you would then also have to write the
tool that reads those info node values
and creates the autosave, archive, ... config files.
-Kay
Re: Record info nodes? Re: PV save and restore tool sought Tim Mooney
PV save and restore tool sought Rock, Judith E.
Re: PV save and restore tool sought Thomas Birke
Re: PV save and restore tool sought Emmanuel Mayssat
Re: PV save and restore tool sought Carl Lionberger
Prev: edm: bug-reports unnecessary? Ralph Lange
Next: EE jobs at NSLS II: FPGA programming and Electrical Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV save and restore tool sought (correction) Carl Lionberger
Next: Re: Record info nodes? Re: PV save and restore tool sought Tim Mooney
