1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Use of waveform records
To: "Touchard Dominique" <[email protected]>, <[email protected]>
Date: Fri, 5 Oct 2007 11:32:58 -0500
One thought on this.
Because you must do 2 Modbus operations to write a 32-bit value with
Modbus, I suspect that the power supply only updates the value when you
write one of the 16-bit words, i.e. either the most-significant or
least-significant 16 bits.  You should read the documentation to find
out which one actually updates the power supply and make your database
write that value last.  Otherwise you will get a momentary garbage
output if you do it in the wrong order.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Mark Rivers
> Sent: Friday, October 05, 2007 11:23 AM
> To: Touchard Dominique; [email protected]
> Hi Dominique,
> Sorry for the delay in replying to this, I was on vacation.
> I think an easier solution to this problem is to use 2 calc records to
> convert the 32-bit integer to 2 16-bit integers, and write
> those to the
> Modbus driver using function 6.  Then you don't have to write any C
> code, just a simple database.
> PowerSupply (longout) -> calc1 (16 LSB) -> longout1 -> Modbus
>                       -> calc2 (16 MSB) -> longout2 -> Modbus
> I don't recommend modifying the driver, because a 32-bit
> integer is not
> a standard Modbus data type, and we could end up with all sorts of
> modifications for non-standard data types.
> Mark
> Touchard Dominique
> > Sent: Wednesday, September 19, 2007 8:44 AM
> > To: [email protected]
> > Subject: Use of waveform records
> > Hi,
> > we are working on/with the Epics modbus tcp driver written by Mark
> > Rivers. We need to write a 32 bits integer value in a power supply
> > command control interface.  First we thought to write an asyn32Int
> > record with the number 6 modbus function.  Immediatly, we
> saw that the
> > driver uses the number 6 modbus function which works only on
> > a 16 bits word.
> > After reading the Modbus Driver Support documentation, we
> saw that we
> > have to use a two value length waveform record.
> > First question : is this correct ?
> > Second question : do we have to use the gensub record to manipulate
> > values inside a waveform record ? In this case, is there any example
> > that shows how to do this ? Could somebody send us an example
> > on this ?
> > Third question : Is a bad idea to modify the modbus driver
> in the goal
> > to write a asyn32Int 32 bits integer record with the
> number 16 modbus
> > function ?
> > Thanks for your help .
> > Dominique Touchard.
Re: Use of waveform records Touchard Dominique
RE: Use of waveform records Mark Rivers
Prev: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Emmanuel Mayssat
Next: Re: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Jukka Pietarinen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Use of waveform records Mark Rivers
Next: Re: Use of waveform records Touchard Dominique
