Hi Mark,
Thanks for your answer. I agree with you. We mustn't modify the driver.
The power supply could work with two longout records. In the future, I
will need to know how to work with a waveform, an SNL or Gensub code.
So I decided to try these tools. I have written an SNL code which does
this conversion. I know this is not the best solution. I will try a
gensub record soon.
I tried to convert the 32 bit integer value into 2 16 bits values with
a calc record. Because of float conversion troubles, I don't get
through to get the right values. I have a beginner's question : does
the bit left shift
work like C code? Can I write something like A << 16 in the calc
_expression_?
Perhaps I discovered a modbus driver "feature" ? I created one modbus
number 4 read function which read 11 bytes. I tested three waveform
input records. These three records read 3 different values on different
offsets. These 3 records read the offset 0 ???!!!
So I decided to create only one input waveform which read the whole
bytes. It works fine. At present, the SNL code converts the values.
About ai/ao records, I will need to write and read float values with
the Modbus driver. I saw integer examples. Ai/ao examples work with
asyn32int type. Did you test asynFloat64 values ? Do I have to use
waveform records (ie 32bits : sign:1bit exponent:8bits fraction:23bits)
Thanks for your help.
Dominique.
Mark Rivers a écrit :
One thought on this.
Because you must do 2 Modbus operations to write a 32-bit value with
Modbus, I suspect that the power supply only updates the value when you
write one of the 16-bit words, i.e. either the most-significant or
least-significant 16 bits. You should read the documentation to find
out which one actually updates the power supply and make your database
write that value last. Otherwise you will get a momentary garbage
output if you do it in the wrong order.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Friday, October 05, 2007 11:23 AM
To: Touchard Dominique; [email protected]
Subject: RE: Use of waveform records
Hi Dominique,
Sorry for the delay in replying to this, I was on vacation.
I think an easier solution to this problem is to use 2 calc records to
convert the 32-bit integer to 2 16-bit integers, and write
those to the
Modbus driver using function 6. Then you don't have to write any C
code, just a simple database.
PowerSupply (longout) -> calc1 (16 LSB) -> longout1 -> Modbus
-> calc2 (16 MSB) -> longout2 -> Modbus
I don't recommend modifying the driver, because a 32-bit
integer is not
a standard Modbus data type, and we could end up with all sorts of
modifications for non-standard data types.
Touchard Dominique
Sent: Wednesday, September 19, 2007 8:44 AM
To: [email protected]
Subject: Use of waveform records
we are working on/with the Epics modbus tcp driver written by Mark
Rivers. We need to write a 32 bits integer value in a power supply
command control interface. First we thought to write an asyn32Int
record with the number 6 modbus function. Immediatly, we
saw that the
driver uses the number 6 modbus function which works only on
a 16 bits word.
After reading the Modbus Driver Support documentation, we
saw that we
have to use a two value length waveform record.
First question : is this correct ?
Second question : do we have to use the gensub record to manipulate
values inside a waveform record ? In this case, is there any example
that shows how to do this ? Could somebody send us an example
on this ?
Third question : Is a bad idea to modify the modbus driver
in the goal
to write a asyn32Int 32 bits integer record with the
number 16 modbus
function ?
Thanks for your help .
Dominique Touchard.
- RE: Use of waveform records Mark Rivers
Re: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Andrew Johnson
Re: Asyn/VXI-11 problems Dirk Zimoch
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
