1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CAMAC IO
To: "EPICS tech-talk" <[email protected]>
Date: Tue, 9 Oct 2007 22:05:49 -0700
I am writing a soft IOC based on asyn which will do CAMAC IO via KS3988 GPIB crate controller.  I have two problems that I am not sure how to solve.
1. write a counted array of bytes containing numeric values to the crate controller.  What record type is well suited for that?
2. Also, What record type should I use to read an array of bytes from the crate controller?
Unrelated question is, Is it possible to modify a field value in a record from within a subroutine?  To be more specific, I have a sub record and from its process subroutine I want to modify a field in another record.  Can that be done?
Zen
RE: CAMAC IO Paul Sichta
Re: CAMAC IO Tim Mooney
Prev: Opportunity at Fermilab Sharon Lackey
Next: ASYN - calling read after interrupt - fix :) Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CAMAC IO Paul Sichta
