1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CAMAC IO
To: "TechTalk EPICS" <[email protected]>
Date: Wed, 10 Oct 2007 08:36:50 -0400
Zen,
I use waveform arrays, although my device driver is not ASYN but ht2992 VME
CAMAC SHD.
The sub record may have an OUT link that you can write to from your process
routine (can't recall).  Otherwise you can put your value into the sub
record's VAL (or other 'spare' field) and FLNK to another passive scan record
that can INP and OUT link to the target record's field (assuming that field
can be modified at runtime).
-ps
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of Szalata, Zenon M.
Sent: Wednesday, October 10, 2007 1:06 AM
To: EPICS tech-talk
Subject: CAMAC IO
I am writing a soft IOC based on asyn which will do CAMAC IO via KS3988 GPIB
crate controller.  I have two problems that I am not sure how to solve.
1. write a counted array of bytes containing numeric values to the crate
controller.  What record type is well suited for that?
2. Also, What record type should I use to read an array of bytes from the
crate controller?
Unrelated question is, Is it possible to modify a field value in a record
from within a subroutine?  To be more specific, I have a sub record and from
its process subroutine I want to modify a field in another record.  Can that
be done?
Zen
CAMAC IO Szalata, Zenon M.
Prev: Re: ASYN - calling read after interrupt - fix :) Heinrich du Toit
Next: Re: CAMAC IO Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CAMAC IO Szalata, Zenon M.
