1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stream device
To: "Dirk Zimoch" <[email protected]>, "Szalata, Zenon M." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 25 Oct 2007 09:48:43 -0500
Hi Zen,
Please try adding the asynSetTraceMask command to your st.cmd right
after the vxi11Configure command.
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
asynSetTraceMask("LO",0,1)
That will force a connection to the controller before iocInit.  See if
it helps.  If it does not help then change the line to:
asynSetTraceMask("LO",0,255)
so we can get a complete printout of what is happening.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Dirk Zimoch
> Sent: Thursday, October 25, 2007 6:46 AM
> To: Szalata, Zenon M.
> Cc: EPICS tech-talk
> Subject: Re: Stream device
> Hi Zen,
> the @init handler runs during iocInit, to be exact during
> init_record. Maybe the
> vxi11 has not yet connected by that time (when
> interruptAccept is still 0). I
> have to check that. I only tested it with serial and TCP
> ports so far.
> Unfortunately, not all asyn ports behave the same.
> I have not time this week any more. I hope I can help you by
> the end of next week.
> Dirk
> Szalata, Zenon M. wrote:
> > I am learning to use stream device to implement a soft IOC
> to control an Agilent 33220A waveform generator, which is
> attached to an ICS 8065 Ethernet-GPIB controller.  I have a
> very simple program at this point.  It consists of two
> records: ai and ao and a very simple protocol file.  I am
> unable to use the @init{} command/handler.  Without the
> @init{} commented out the program works as it should.  But
> when I uncomment either of the two @init{} statements an
> error results. Here is the output:
> > zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
> > #!../../bin/linux-x86/atest
> > < envPaths
> > epicsEnvSet(ARCH,"linux-x86")
> > epicsEnvSet(IOC,"iocagwfg")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
> > epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
> epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
> epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
> > epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
> > cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
> > ## Register all support components
> > dbLoadDatabase("dbd/atest.dbd",0,0)
> > atest_registerRecordDeviceDriver(pdbbase)
> > dbLoadRecords("db/atest.db","P=AG:")
> > cd
> /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
> > iocInit()
> > Starting iocInit
> > ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
> > ## EPICS Base built Oct  2 2007
> > 2007/10/24 18:21:44.742 L0 port not connected
> > 2007/10/24 18:21:45.307 AG:RFreq: asynError in write: L0
> port is not connected
> > 2007/10/24 18:21:45.308 AG:RFreq: @init handler failed
> > 2007/10/24 18:21:45.308 AG:RFreq: Record initialization failed
> > 2007/10/24 18:21:45.308 AG:WFreq: asynError in write: L0
> > 2007/10/24 18:21:45.308 AG:WFreq: @init handler failed
> > 2007/10/24 18:21:45.308 AG:WFreq: Record initialization failed
> > Bad init_rec return value  PV: AG:WFreq ao: init_record
> > iocInit: All initialization complete
> > epics> exit
> > Here is my atest.db:
> > record( ai,"$(P)RFreq"){
> >   field( DESC, "read frequency")
> >   field( DTYP, "stream")
> >   field( SCAN, "10 second")
> >   field( PREC, "2")
> >   field( EGU,  "Hz")
> >   field( INP,  "@atest.proto rFreq L0 8")
> > record( ao,"$(P)WFreq"){
> >   field( DESC, "write frequency")
> >   field( SCAN, "Passive")
> >   field( PREC, "2")
> >   field( EGU,  "Hz")
> >   field( OUT,  "@atest.proto wFreq L0 8")
> > And atest.proto, shown here with both @init statements
> commented out:
> > # file: atest.proto
> > Terminator=LF;
> > #@init{ out " ";}
> > rFreq{
> >  out "FREQ?"; in "%f";
> > wFreq{
> >  out "FREQ %f";
> > # @init{ rFreq;}
> > Also here is atestApp/src/Makefile
> > TOP=../..
> > include $(TOP)/configure/CONFIG
> > #  ADD MACRO DEFINITIONS AFTER THIS LINE
> > # build an ioc application
> > PROD_IOC = atest
> > DBD += atest.dbd
> > # atest.dbd will be made up from these files:
> > atest_DBD += base.dbd
> > atest_DBD += atestSup.dbd
> > atest_DBD += stream.dbd
> > atest_DBD += asyn.dbd
> > atest_DBD += drvVxi11.dbd
> > # <name>_registerRecordDeviceDriver.cpp will be created
> from <name>.dbd
> > atest_SRCS += atest_registerRecordDeviceDriver.cpp
> > atest_SRCS_DEFAULT += atestMain.cpp
> > atest_SRCS_vxWorks += -nil-
> > #The following adds support from base/src/vxWorks
> > atest_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
> > #add a definition for each support application used by this
> application
> > atest_LIBS += asyn
> > atest_LIBS += stream
> > #atest_LIBS += genSub
> > #atest_LIBS += calc
> > atest_LIBS += $(EPICS_BASE_IOC_LIBS)
> > include $(TOP)/configure/RULES
> > #  ADD RULES AFTER THIS LINE
> > And contents of my atestSup.dbd:
> > registrar( drvAsynIPPortRegisterCommands)
> > When the @init statements are commented out, this is what I get:
> > < envPaths
> > cd
> > iocInit()
> > Starting iocInit
> > epics> dbl
> > AG:RFreq
> > AG:WFreq
> > epics>
> > And I can examine the value read in a very simple edm screen.
> > Sorry for such a lengthy note.  Thanks for helping,
> > Zen
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
RE: Stream device Szalata, Zenon M.
Re: Stream device Dirk Zimoch
Prev: Epicstcl Eric Berryman
Next: RE: another question on custom record stuff Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream device Dirk Zimoch
Next: RE: Stream device Szalata, Zenon M.
