No, this did not fix the problem. Here is what I get first with 1, then with 255 in the third argument...
#!../../bin/linux-x86/atest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocagwfg")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
dbLoadDatabase("dbd/atest.dbd",0,0)
atest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
asynSetTraceMask( "L0",0,1)
dbLoadRecords("db/atest.db","P=AG:")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Oct 2 2007
2007/10/25 09:08:49.526 L0 port not connected
2007/10/25 09:08:50.062 asynManager::asynConnectCallback, port L0 error calling
asynCommon->connect L0 addr 0 vxiConnect request but already connected
2007/10/25 09:08:50.083 AG:RFreq: asynError in write: L0 port is not connected
2007/10/25 09:08:50.083 AG:RFreq: @init handler failed
2007/10/25 09:08:50.083 AG:RFreq: Record initialization failed
2007/10/25 09:08:50.083 AG:WFreq: asynError in write: L0 port is not connected
2007/10/25 09:08:50.084 AG:WFreq: @init handler failed
2007/10/25 09:08:50.084 AG:WFreq: Record initialization failed
Bad init_rec return value PV: AG:WFreq ao: init_record
iocInit: All initialization complete
epics> exit
zms@esaux1 $
zms@esaux1 $
zms@esaux1 $
zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
< envPaths
asynSetTraceMask( "L0",0,255)
iocInit()
Starting iocInit
2007/10/25 09:09:52.303 L0 port not connected
2007/10/25 09:09:52.845 asynManager connect queueCallback port:L0
2007/10/25 09:09:52.845 L0 addr 0 vxiConnect
2007/10/25 09:09:52.845 asynManager::asynConnectCallback, port L0 error calling
2007/10/25 09:09:52.865 AG:RFreq: asynError in write: L0 port is not connected
2007/10/25 09:09:52.865 AG:RFreq: @init handler failed
2007/10/25 09:09:52.865 AG:RFreq: Record initialization failed
2007/10/25 09:09:52.865 AG:WFreq: asynError in write: L0 port is not connected
2007/10/25 09:09:52.865 AG:WFreq: @init handler failed
2007/10/25 09:09:52.865 AG:WFreq: Record initialization failed
epics> 2007/10/25 09:10:02.868 AG:RFreq: asynError in write: L0 port is not conn
ected
exit
Zen
-----Original Message-----
Sent: Thursday, October 25, 2007 7:49 AM
To: Dirk Zimoch; Szalata, Zenon M.
Cc: EPICS tech-talk
Subject: RE: Stream device
Hi Zen,
Please try adding the asynSetTraceMask command to your st.cmd right after the vxi11Configure command.
asynSetTraceMask("LO",0,1)
That will force a connection to the controller before iocInit. See if it helps. If it does not help then change the line to:
asynSetTraceMask("LO",0,255)
so we can get a complete printout of what is happening.
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Dirk Zimoch
> Sent: Thursday, October 25, 2007 6:46 AM
> To: Szalata, Zenon M.
> Cc: EPICS tech-talk
> Subject: Re: Stream device
> Hi Zen,
> the @init handler runs during iocInit, to be exact during init_record.
> Maybe the
> vxi11 has not yet connected by that time (when interruptAccept is
> still 0). I have to check that. I only tested it with serial and TCP
> ports so far.
> Unfortunately, not all asyn ports behave the same.
> I have not time this week any more. I hope I can help you by the end
> of next week.
> Dirk
> Szalata, Zenon M. wrote:
> > I am learning to use stream device to implement a soft IOC
> to control an Agilent 33220A waveform generator, which is attached to
> an ICS 8065 Ethernet-GPIB controller. I have a very simple program at
> this point. It consists of two
> records: ai and ao and a very simple protocol file. I am unable to
> use the @init{} command/handler. Without the @init{} commented out
> the program works as it should. But when I uncomment either of the
> two @init{} statements an error results. Here is the output:
> > #!../../bin/linux-x86/atest < envPaths
> > cd
> > iocInit()
> > Starting iocInit
> > ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$ ## EPICS Base
> > built Oct 2 2007
> > 2007/10/24 18:21:44.742 L0 port not connected
> > 2007/10/24 18:21:45.307 AG:RFreq: asynError in write: L0
> > 2007/10/24 18:21:45.308 AG:RFreq: @init handler failed
> > 2007/10/24 18:21:45.308 AG:RFreq: Record initialization failed
> > 2007/10/24 18:21:45.308 AG:WFreq: asynError in write: L0
> > 2007/10/24 18:21:45.308 AG:WFreq: @init handler failed
> > 2007/10/24 18:21:45.308 AG:WFreq: Record initialization failed Bad
> > epics> exit
> > Here is my atest.db:
> > record( ai,"$(P)RFreq"){
> > field( DESC, "read frequency")
> > field( DTYP, "stream")
> > field( SCAN, "10 second")
> > field( PREC, "2")
> > field( EGU, "Hz")
> > field( INP, "@atest.proto rFreq L0 8") } record( ao,"$(P)WFreq"){
> > field( DESC, "write frequency")
> > field( SCAN, "Passive")
> > field( PREC, "2")
> > field( EGU, "Hz")
> > field( OUT, "@atest.proto wFreq L0 8") }
> > And atest.proto, shown here with both @init statements
> commented out:
> > # file: atest.proto
> > Terminator=LF;
> > #@init{ out " ";}
> > rFreq{
> > out "FREQ?"; in "%f";
> > wFreq{
> > out "FREQ %f";
> > # @init{ rFreq;}
> > Also here is atestApp/src/Makefile
> > TOP=../..
> > include $(TOP)/configure/CONFIG
> > # ADD MACRO DEFINITIONS AFTER THIS LINE
> > # build an ioc application
> > PROD_IOC = atest
> > DBD += atest.dbd
> > # atest.dbd will be made up from these files:
> > atest_DBD += base.dbd
> > atest_DBD += atestSup.dbd
> > atest_DBD += stream.dbd
> > atest_DBD += asyn.dbd
> > atest_DBD += drvVxi11.dbd
> > # <name>_registerRecordDeviceDriver.cpp will be created
> from <name>.dbd
> > atest_SRCS += atest_registerRecordDeviceDriver.cpp
> > atest_SRCS_DEFAULT += atestMain.cpp
> > atest_SRCS_vxWorks += -nil-
> > #The following adds support from base/src/vxWorks atest_OBJS_vxWorks
> > += $(EPICS_BASE_BIN)/vxComLibrary
> > #add a definition for each support application used by this
> application
> > atest_LIBS += asyn
> > atest_LIBS += stream
> > #atest_LIBS += genSub
> > #atest_LIBS += calc
> > atest_LIBS += $(EPICS_BASE_IOC_LIBS)
> > include $(TOP)/configure/RULES
> > # ADD RULES AFTER THIS LINE
> > And contents of my atestSup.dbd:
> > registrar( drvAsynIPPortRegisterCommands)
> > When the @init statements are commented out, this is what I get:
> > < envPaths
> > cd
> > iocInit()
> > Starting iocInit
> > built Oct 2 2007
> > epics> dbl
> > AG:RFreq
> > AG:WFreq
> > epics>
> > And I can examine the value read in a very simple edm screen.
> > Sorry for such a lengthy note. Thanks for helping, Zen
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
- RE: Stream device Mark Rivers
- Re: Stream device Dirk Zimoch
Re: building synApps on Win32-x86 Eric Norum
RE: building synApps on Win32-x86 Mark Rivers
<2007>
2025
2026
<2007>
2025
2026
