I patched the RawConverter to support both signed and unsigned conversion. To stay backward compatible, %r converts signed. I use %0r for unsigned now. The new version is attached. Dirk Emmanuel Mayssat wrote: Dirk,
/*************************************************************** * StreamDevice Support * * * * (C) 1999 Dirk Zimoch ([email protected]) * * (C) 2005 Dirk Zimoch ([email protected]) * * * * This is the raw format converter of StreamDevice. * * Please refer to the HTML files in ../doc/ for a detailed * * documentation. * * * * If you do any changes in this file, you are not allowed to * * redistribute it any more. If there is a bug or a missing * * feature, send me an email and/or your patch. If I accept * * your changes, they will go to the next release. * * * * DISCLAIMER: If this software breaks something or harms * * someone, it's your problem. * * * ***************************************************************/ #include "StreamFormatConverter.h" #include "StreamError.h" // Raw Bytes Converter %r class RawConverter : public StreamFormatConverter { int parse(const StreamFormat&, StreamBuffer&, const char*&, bool); bool printLong(const StreamFormat&, StreamBuffer&, long); int scanLong(const StreamFormat&, const char*, long&); }; int RawConverter:: parse(const StreamFormat&, StreamBuffer&, const char*&, bool) { return long_format; } bool RawConverter:: printLong(const StreamFormat& format, StreamBuffer& output, long value) { int prec = format.prec; // number of bytes from value if (prec == -1) prec = 1; // default: 1 byte int width = prec; // number of bytes in output if (format.width > width) width = format.width; char byte = 0; if (format.flags & alt_flag) // lsb first (little endian) { while (prec--) { byte = static_cast<char>(value); output.append(byte); value >>= 8; width--; } if (format.flags & zero_flag) { // fill with zero byte = 0; } else { // fill with sign byte = (byte & 0x80) ? 0xFF : 0x00; } while (width--) { output.append(byte); } } else // msb first (big endian) { if (format.flags & zero_flag) { // fill with zero byte = 0; } else { // fill with sign byte = ((value >> (8 * (prec-1))) & 0x80) ? 0xFF : 0x00; } while (width > prec) { output.append(byte); width--; } while (prec--) { output.append(static_cast<char>(value >> (8 * prec))); } } return true; } int RawConverter:: scanLong(const StreamFormat& format, const char* input, long& value) { long length = 0; long val = 0; int width = format.width; if (width == 0) width = 1; // default: 1 byte if (format.flags & skip_flag) { return width; // just skip input } if (format.flags & alt_flag) { // little endian (sign extended)*/ unsigned int shift = 0; while (--width && shift < sizeof(long)*8) { val |= ((unsigned char) input[length++]) << shift; shift += 8; } if (width == 0) { if (format.flags & zero_flag) { // fill with zero val |= ((unsigned char) input[length++]) << shift; } else { // fill with sign val |= ((signed char) input[length++]) << shift; } } length += width; // ignore upper bytes not fitting in long } else { // big endian */ if (format.flags & zero_flag) { // fill with zero val = (unsigned char) input[length++]; } else { // fill with sign val = (signed char) input[length++]; } while (--width) { val <<= 8; val |= (unsigned char) input[length++]; } } value = val; return length; } RegisterConverter (RawConverter, "r");
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
