1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Streams questions (how to read +00011-01 as 11e-01=1.1)
To: TechTalk EPICS <[email protected]>
Date: Wed, 21 Nov 2007 17:22:45 +0100
Hi all,
Here is an ad-hoc format converter for a "mantissa and exponent representation without e". In other words: Two signed decimal integers like in +01234-56 meaning 1234e-56 (or 1.234e-43)
Eric and someone else I don't remember requested it.
Put the converter file in the src directory, add FORMATS+=Exponential to CONFIG_STREAM and requild. The format is %m. (Any better suggestion?)
Maximal field width does not work at the moment. Low level, it just reads %d%d.
Output is  not implemented because it is not clear how to do the formatting,
Why +00011-01 and not +00110-02 or +11000-04 ?
Was +00011-01 originally 1.1000000000000 or 1.11 or 1.10000000000001 ?
What are the rules for rounding and precision?
Dirk
Dirk Zimoch wrote:
Hi Eric,
at the moment, I don't have a direct support for this. But I tried the following construct:
record (ai, "$(P):read")
    field(DTYP, "stream")
    field(INP,  "@proto read($(P):calc) terminal")
    field(FLNK, "$(P):calc")
record (calcout, "$(P):calc")
    field(CALC, "A*10^B")
    field(OUT, "$(P):read")
with the protocol
Terminator="\r\n";
read {
    in "U1";
    in "%(\$1.A)d%(\$1.B)d";
The protocol reads mantissa and exponent as decimal integer and put them into fields A and B of a calc record. This record calculates the value and writes it back to the input record.
I already got a request for the same format earlier but have not yet found the time to implement it.
Dirk
Eric Berryman wrote:
Hello!
I've run into a problem I'm guessing others have solved using the
Streams module.  I have a device that outputs reads in the format:
U1\r\n+00011-01\r\n
meaning 11e-01 , which would be the preferred format for using a
general format specifier in the protocol file.
What would be the format to successfully read in this number from the
Streams protocol file?
(Or, will I have to run as a string read through a c filter program,
sub record)
Thank you!
Eric
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
* StreamDevice Support                                         *
* (C) 1999 Dirk Zimoch ([email protected])          *
* (C) 2007 Dirk Zimoch ([email protected])                    *
* This is a custom exponential format converter for            *
* StreamDevice.                                                *
* The number is represented as two signed integers, mantissa   *
* and exponent, like in +00011-01                              *
* Please refer to the HTML files in ../doc/ for a detailed     *
* documentation.                                               *
* If you do any changes in this file, you are not allowed to   *
* redistribute it any more. If there is a bug or a missing     *
* feature, send me an email and/or your patch. If I accept     *
* your changes, they will go to the next release.              *
* DISCLAIMER: If this software breaks something or harms       *
* someone, it's your problem.                                  *
#include "StreamFormatConverter.h"
#include "StreamError.h"
#include <math.h>
// Exponential Converter %m: format +00351-02 means +351e-2
class ExponentialConverter : public StreamFormatConverter
    virtual int parse(const StreamFormat&, StreamBuffer&, const char*&, bool);
    virtual int scanDouble(const StreamFormat&, const char*, double&);
int ExponentialConverter::
parse(const StreamFormat& fmt, StreamBuffer& info,
    const char*& source, bool scanFormat)
    if (!scanFormat)
        error("At the moment for %%m format only input is implemented\n");
        return false;
    return double_format;
scanDouble(const StreamFormat& fmt, const char* input, double& value)
    int mantissa;
    int exponent;
    int length = -1;
    sscanf(input, "%d%d%n", &mantissa, &exponent, &length);
    if (fmt.flags & skip_flag) return length;
    if (length == -1) return -1;
    value = (double)(mantissa) * pow(10, exponent);
    return length;
RegisterConverter (ExponentialConverter, "m");
Streams questions Eric Berryman
Re: Streams questions Dirk Zimoch
Prev: Re: Stream Raw converter and un/signed integrer Dirk Zimoch
Next: Problems building edm-1-11-0zg David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Streams questions Dirk Zimoch
Next: RE: Streams questions Mohan Ramanathan
