1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: writing your own stream converter
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Mon, 03 Dec 2007 16:59:37 -0800
Dirk,
On Mon, 2007-12-03 at 13:45 -0800, Emmanuel Mayssat wrote:
> To populate several records with the same reply, one needs to use a
> trigger record (a standard ai record (devaiStream)) and other slave
> records (scan set to Intr I/O scan and protocol with only "in"
> directives). The "out" directive is set in the protocol of the trigger
> record.
In the case of long replies, the read request may be broken in 2 or more
segments.
The I/O Intr trick matches the individual "read segment" instead of the
entire reply. Is there a way to change that?
Maybe with the right settings for pollTimeout, replyTimeout, or
readTimeout? By reading the doc I suspect that setting pollTimeout
correctly should do the trick. But with me it doesn't...
Emmanuel
Stream protocol configuration Emmanuel Mayssat
writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream cronverter Emmanuel Mayssat
Prev: RE: device support for output connected to volatile device Mark Rivers
Next: I want to unsubscribe from tech-talk Aravamuthan Govindan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: writing your own stream cronverter Emmanuel Mayssat
Next: Stream protocol configuration Emmanuel Mayssat
