1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: I want to unsubscribe from tech-talk
To: [email protected]
Date: Tue, 4 Dec 2007 13:41:22 +0530
Hello,
I unsubscribed from tech-talk on 22/11/07 I got confirmation mail
on Thu, Nov 22, 2007 at 5:15 PM
Per your request
       "delete tech-talk"
'[email protected]' was DELETED from the 'tech-talk' mailing list.
But I continue to get mails (event after a week!).
I tried to unsubscribe again I got the following mail
on Tue, Dec 4, 2007 at 1:03 PM
Per your request
       "unsubscribe tech-talk"
'[email protected]' was NOT FOUND on the 'tech-talk' mailing list.
Please unsubscribe me from the tech-talk.
Thanks in advance
Amuthan.
On 12/4/07, Emmanuel Mayssat <[email protected]> wrote:
> Dirk,
> On Mon, 2007-12-03 at 13:45 -0800, Emmanuel Mayssat wrote:
> > To populate several records with the same reply, one needs to use a
> > trigger record (a standard ai record (devaiStream)) and other slave
> > records (scan set to Intr I/O scan and protocol with only "in"
> > directives). The "out" directive is set in the protocol of the trigger
> > record.
> In the case of long replies, the read request may be broken in 2 or more
> segments.
> The I/O Intr trick matches the individual "read segment" instead of the
> entire reply. Is there a way to change that?
> Maybe with the right settings for pollTimeout, replyTimeout, or
> readTimeout? By reading the doc I suspect that setting pollTimeout
> correctly should do the trick. But with me it doesn't...
> Emmanuel
Prev: Re: writing your own stream converter Emmanuel Mayssat
Next: Re: writing your own stream cronverter Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: device support for output connected to volatile device John Dobbins
Next: Multiple IOC Robert Emery
