1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Java CA context cleanup issues on Linux?
To: tech talk <[email protected]>
Date: Wed, 05 Dec 2007 10:04:09 -0500
On Dec 4, 2007, at 19:32 , J. Lewis Muir wrote:
Your example works for me with t...
* Red Hat Enterprise Linux WS release 3 (Taroon Update 9)...
Test host either RedHat Enterprise Linux Client release 5.1 with
kernel 2.6.18-53.el5 and g++ (GCC) 4.1.2 20070626 (Red Hat 4.1.2-14),
or the older Red Hat Enterprise Linux AS release 4 (Nahant Update 4) with
kernel 2.6.9-42.EL and g++ (GCC) 3.4.6 20060404 (Red Hat 3.4.6-3).
Both are single-core CPUs.
Found an older computer:
RedHat Enterprise Linux AS release 3 (Taroon Update 2),
kernel 2.4.21-15ELsmp, g++ 3.2.3
Still errors in channel creation after destroying the context
and then creating a new one, but instead of
 "pthread_create error Invalid argument"
I get
"pthread_attr_setschedparam error Invalid argument"
with that setup.
Also used EPICS base R3.14.9 instead of R3.14.8.2.
Same difference.
... could change your dispose() method calls to destroy().
Since dispose() calls destroy() and catches any exception and discards it, you may not be seeing an exception that could help with debugging.
Good idea in general, I'll do that from now on, but no difference in this matter.
... event dispatcher ....
No difference between the Queued and DirectEventDispatcher.
I gather the variations of this problem are caused
by different pthread implementations.
Meanwhile, a usable workaround for me is to keep JCA context open.
Closing channels and opening different ones is OK,
but switching from CAJ to JCA requires a complete application restart.
-Kay
Re: Java CA context cleanup issues on Linux? Kay-Uwe Kasemir
Re: Java CA context cleanup issues on Linux? J. Lewis Muir
Prev: Problems building edm-1-11-0zg Cuzon Stephane
Next: Re: device support for output connected to volatile device John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Java CA context cleanup issues on Linux? J. Lewis Muir
Next: string monitoring in medm Umashankar Panda
