1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A patch for medm
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Thu, 06 Dec 2007 11:49:16 -0600
Kate Feng wrote:
MEDM version 3.03 :
When I defined only three states for a  mbbo record,
the following warning message will pop up whenever  CA is
connected.
menuUpdateValueCb: Got state 3.
 Only have strings for 3 states (starting at 0).
 Kate:Mset_formatmode
Your record has three state strings for states #0, 1 and 2, but the VAL field is set to 3 which does not correspond to a valid state. Either you need to define a fourth state string, or change the record so it is never set to the value 3. This is not a bug in MEDM.
A minor patch stops the warining message:
diff -c -u medmMenu.c.orig medmMenu.c
--- medmMenu.c.orig Tue Jun 10 12:13:27 2003
+++ medmMenu.c Thu Nov 29 07:24:48 2007
@@ -510,7 +510,7 @@
        XmNnumChildren,&numChildren,
        NULL);
      i = (int) pr->value;
-      if((i >=0) && (i < (int) numChildren)) {
+      if((i >=0) && (i <= (int) numChildren)) {
This change would add an off-by-one bug to MEDM, which we will not do. As the warning message states, there are only three defined states for this record starting at state number 0. With your fix in place, try putting the integer value 4 into that MBBO record and you'll get the same problem, showing that you haven't fixed what you think you have.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Re: A patch for medm Kate Feng
Prev: Re: Multiple IOC Robert Emery
Next: Re: Stream protocol configuration Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: A patch for medm Kate Feng
Next: Re: A patch for medm Kate Feng
