1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StringIn and StringOut
To: [email protected]
Date: Mon, 24 Mar 2008 14:43:52 -0400
On 3/24/08 10:20 AM, Andrew Johnson wrote:
> Does anybody know if it's possible to transcode RealVideo files into any
> widely used non-proprietary formats, and if so what tools I need to do
> that?
> Thanks,
> - Andrew
Hi, Andrew.
I think the software FFmpeg <http://ffmpeg.mplayerhq.hu/> would be able
to transcode RealVideo to a format of your choice (I haven't actually
tried doing this though).  Of course, you would almost certainly be
making a lossy copy of a lossy copy at that point, so if you have higher
quality source video, it would be better to use that as your source when
transcoding to a new format.
As far as formats go, Flash Video may be a good choice from the
standpoint of being a widely used and supported format.  For example,
YouTube uses this format.  It would require a Flash Video player (e.g.
Adobe Flash Player plug-in for a web browser).  A large percentage of
existing web browsers already have an Adobe Flash plug-in.  However, I
believe Flash Video normally uses a proprietary codec, so if you truly
want a non-proprietary format, Flash Video won't work.
One non-proprietary video codec is Theora <http://www.theora.org/>.  It
is usually used inside an Ogg container format.  Wikipedia uses Ogg
Theora for their video content:
  <http://en.wikipedia.org/wiki/Wikipedia:
   Creation_and_usage_of_media_files#Video>
Unfortunately, this format is not supported by default on many
platforms.  Wikipedia's Media help page talks about this and provides
instructions for installing software to play this format:
  <http://en.wikipedia.org/wiki/Wikipedia:Media_help>
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
StringIn and StringOut David Dudley
Re: StringIn and StringOut Andrew Johnson
Prev: Re: StringIn and StringOut Daron Chabot
Next: Re: StringIn and StringOut David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
