1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Change input links run-time in a db
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Thu, 08 May 2008 09:31:21 -1000
Ulrik, Tim,
my first reaction was: why do you want to do this
anyway?
Can't you just feed both channels, and a "switch",
into a calc record or some such and switch values?
Is there a good reason to actually switch the input
_channel_ rather than just the value?
Aloha,
Maren
Tim Mooney wrote:
Dear folks,  Changing links at runtime has to be done via Channel Access.
This is documented in the App Dev Guide (15.5 Runtime Link Modification).
The reason isn't documented there (or at least I haven't found it) but
anyway it's because lock sets have to be recalculated, and you can't
do that while you're running under the protection of a lock set that's
going to be recalculated.
RE: Change input links run-time in a db Mark Rivers
Re: Change input links run-time in a db Tim Mooney
Change input links run-time in a db Pedersen, UK (Ulrik)
Re: Change input links run-time in a db Luedeke Andreas
RE: Change input links run-time in a db Pedersen, UK (Ulrik)
Prev: New version of the sscan module Tim Mooney
Next: RE: Change input links run-time in a db Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Change input links run-time in a db Tim Mooney
