1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS building problems
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Wed, 14 May 2008 17:29:42 -0700
Kate Feng wrote:
Eric Williams wrote:
Any guesses what went wrong? Build environment is Linux 2.6.9-55.0.9.ELsmp (RedHat Enterprise WS rel. 4) x86_64 and gcc 3.4.5.
Since you use RHEL4,  if it is for RTEMS4.9, you should
read this thread :
http://www.rtems.com/ml/rtems-users/2008/may/msg00113.html
RHEL5 for RTEMS4.9 development will be OK.
Cheers,
Kate
Thanks to Eric Norum's help, the immediate problem appears to be the gcc in RHEL 4, which is v3.4.5. Setting CC to 'gcc4' in the getAndBuildTools.sh script and exporting it seems to have gotten me past the assembler problem. But I may run into the gm4 problem later and be forced to upgrade my Linux installation. <sigh>
eric
Re: RTEMS building problems Eric Norum
RTEMS building problems Eric Williams
Re: RTEMS building problems Kate Feng
Prev: RE: Queensgate NPS3*** series piezo controller Pedersen, UK (Ulrik)
Next: Re: RTEMS building problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS building problems Kate Feng
