1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS building problems
To: Eric Williams <[email protected]>
Cc: epics tech-talk <[email protected]>
Date: Wed, 14 May 2008 20:23:01 -0500
I think that m4 is needed only for the 'bootstrap' phase which is not needed if you get a 'point' release from OAR.
You need to run the bootstrap pass only if you;re building from CVS.
On May 14, 2008, at 7:29 PM, Eric Williams wrote:
Any guesses what went wrong? Build environment is Linux 2.6.9-55.0.9.ELsmp (RedHat Enterprise WS rel. 4) x86_64 and gcc 3.4.5.
Since you use RHEL4,  if it is for RTEMS4.9, you should
read this thread :
http://www.rtems.com/ml/rtems-users/2008/may/msg00113.html
RHEL5 for RTEMS4.9 development will be OK.
Cheers,
Kate
Thanks to Eric Norum's help, the immediate problem appears to be the gcc in RHEL 4, which is v3.4.5. Setting CC to 'gcc4' in the getAndBuildTools.sh script and exporting it seems to have gotten me past the assembler problem. But I may run into the gm4 problem later and be forced to upgrade my Linux installation. <sigh>
eric
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
RTEMS building problems Eric Williams
Re: RTEMS building problems Kate Feng
Re: RTEMS building problems Eric Williams
Prev: Re: RTEMS building problems Eric Williams
Next: EPICS support for PCI, cPCI, PXI : Digitizers/scopes, AWG and Digital I/O Strategic Test
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: channel archiver make problem. Umashankar Panda
