1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Looking for support for Eurotherm 2404 PID
To: "David Maden" <[email protected]>, "Steve Lewis" <[email protected]>
Cc: Keith Kishiyama <[email protected]>, [email protected]
Date: Sat, 17 May 2008 15:23:45 -0500
Steve,
I just looked at the Eurotherm online documentation.  The 2416 and 2404 can each be ordered with several different communications protocols (Modbus, El-Bisync).  It is encoded in the part number (YM=2-wire RS485 Modbus, etc.).
Looking at the Modbus manual for the 2400 series:
http://www.eurotherm.com.au/control/product/comms/2000_mb_m_ha026230_2.pdf
it looks like my Modbus driver should work.  You just need to define the register addresses for each function in your database.
Sent: Sat 5/17/2008 10:43 AM
To: Steve Lewis
Cc: Keith Kishiyama; [email protected]
Subject: Re: Looking for support for Eurotherm 2404 PID
Steve Lewis wrote:
> The Eurotherm 2404 PID is a temperature controller that uses the Modbus
> protocol over a serial .  Does anyone have a streamdevice/asyn protocol
> or any other device/driver support for it?
We are controlling a couple of furnaces via a Eurotherm 2416 with RS-232-C
interface. I don't know if it uses the same protocol as the 2404 though,
but our code might be a starting point for you.
The protocol of the Eurotherm 2416 includes BCC checksums, which Dirk
Zimoch's stream driver couldn't handle at the time I wrote the EPICS
support. As a result, our code is flat EPICS database of soft records with
an snl program calling functions to send and receive messages to the device
via a pseudo-terminal VxWorks device driver.
Regards, David
                                [email protected]
      _/_/_/   _/   _/_/_/     SLS Experiment Integration Group
     _/       _/   _/         Paul Scherrer Institute
      _/_/   _/     _/_/     CH-5232 Villigen-PSI
         _/ _/         _/   Tel: +41 56 310 3616
    _/_/_/ _/_/_/ _/_/_/   Fax: +41 56 310 5090
RE: Looking for support for Eurotherm 2404 PID Cobb, TM (Tom)
Looking for support for Eurotherm 2404 PID Steve Lewis
Re: Looking for support for Eurotherm 2404 PID David Maden
Prev: Re: Looking for support for Eurotherm 2404 PID David Maden
Next: Re: Listing channels Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Looking for support for Eurotherm 2404 PID Cobb, TM (Tom)
