I want to use genSub record but I don't know how to make it available, I use EPICS 3.14.8. My starting point is the example application obtained with : >makeBaseApp.pl -t exampleApp myGenSubApp >makeBaseApp.pl -i -t exampleBoot myGenSubApp Here is What I did: - In the <top>/configure/RELEASE file I have added the location of the gensub module (GENSUB=$(EPICS_BASE)/../modules/soft/gensub) - then I run the make command in the <top> directory => When I inspect the application tree there is nothing related to the genSub, the genSub record is not available in VDCT. As a first step I would like to do what is done in the example application with the sub record but with a genSub record. Can someone explain me the procedure to have genSub available ? Regards.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
