1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DMA Example
To: [email protected]
Date: Mon, 21 Jul 2008 12:41:47 -0500
Hi Zen,
On Friday 18 July 2008 13:37:37 Szalata, Zenon M. wrote:
> I am trying to implement code to do DMA data transfer from a VME module to
> mv6100 local memory using vxWorks routines: sysTempeDmaStart and
> sysTempeDmaStatus.
I assume you decided not to use my tempeDma.c interface then, since these
routines are the ones from the code that comes with the mv6100 BSP (I don't
think the two will work together properly, so I hope you're not trying to
build a BSP with both included at the same time).  You may be the only person
in the EPICS community using that code.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
DMA Example Szalata, Zenon M.
Prev: Re: MAXv problem update EPICS record Ron Sluiter
Next: Re: VXI resource manger converted to R3.14? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: DMA Example Szalata, Zenon M.
Next: How to introduce usage of genSub ? haquin
