1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to introduce usage of genSub ?
To: haquin <[email protected]>
Cc: [email protected]
Date: Mon, 21 Jul 2008 08:22:04 -0500
You need to add the following line to your .dbd file:
include "genSubRecord.dbd"
Also you need to add something like the following line to your Makefile:
exampleApp_LIBS += genSub
haquin wrote:
Hi all,
I want to use genSub record but I don't know how to make it available, I use EPICS 3.14.8.
My starting point is the example application obtained with :
 >makeBaseApp.pl -t exampleApp myGenSubApp
 >makeBaseApp.pl -i -t exampleBoot myGenSubApp
Here is What I did:
- In the <top>/configure/RELEASE file I have added the location of the gensub module (GENSUB=$(EPICS_BASE)/../modules/soft/gensub)
- then I run the make command in the <top> directory
=> When I inspect the application tree there is nothing related to the genSub, the genSub record is not available in VDCT.
As a first step I would like to do what is done in the example application with the sub record but with a genSub record.
Can someone explain me the procedure to have genSub available ?
Regards.
-- Tim Mooney ([email protected]) (630)252-5417 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
How to introduce usage of genSub ? haquin
Prev: RE: array calc / inverse subarray survey? Rowland, J (James)
Next: Re: MAXv problem update EPICS record Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: How to introduce usage of genSub ? haquin
Next: Amptek PX4 support? Rodney R. Porter
