1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Revisiting a old problem - measuring the insertion device gap
To: <[email protected]>
Date: Tue, 22 Jul 2008 09:37:34 -0500
Josh,
Try http://www.laserdesign.com/default.htm for laser measurement and control
solutions.
This company has experience in the aerospace industry.
HTH,
Debby
-----Original Message-----
On Behalf Of Josh Stein
Sent: Tuesday, July 22, 2008 9:35 AM
To: [email protected]
Subject: Revisiting a old problem - measuring the insertion device gap
Community,
 We have been tasked with designing an interlock system involving the
measurement of our Insertion Devices here at the APS. Being a machine
protection system, it would be preferable to use an independent source
of measurement than is currently used by the control system. In the past
it has been an awkward problem coming up with accurate absolute
measurements of the gap due primarily to the fact that - by necessity -
the area to be measured is typically under a high radiation environment.
I'm trying to approach this problem from a fresh start - without any of
the existing baggage currently encumbering the control system.
So my question to everyone is simple to state, but I cannot come up with
a reasonable solution:
1) For each Insertion Device (ID) the system will need accurate (within
a few microns) and absolute measurement of the gap in two places (up and
down-stream).
2) The transducers need to be radiation "proof" - things like plastics,
teflon and electronics will not survive long enough (if at all) to be viable
In a nutshell, that's really it.
I've investigated a few leads which seem promising, but would like to
hear fresh ideas from the experts (you guys).
Thanks in advance,
--Josh
VXI resource manger converted to R3.14? Nicholas P. DiMonte
Re: VXI resource manger converted to R3.14? Andrew Johnson
Revisiting a old problem - measuring the insertion device gap Josh Stein
Prev: Revisiting a old problem - measuring the insertion device gap Josh Stein
Next: Re: Revisiting a old problem - measuring the insertion device gap David Morris
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
