1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS and CAN field bus
To: EPICS Tech Talk <[email protected]>
Date: Mon, 20 Oct 2008 17:21:39 +0200
Hi all,
is anyone out there connecting from EPICS to CAN field bus using an IOC on PC hardware?
What CAN interface hardware do you use? What OS is this running on? (Linux preferred...)
What's the status of Marty's IP/PCI driver for Linux? (Still listed as 1.0alpha0 on the EPICS web.)
Would you consider putting a Tews TIP810 on such a carrier board to be a good idea?
Thanks for your help!
Ralph
Re: EPICS and CAN field bus Marty Kraimer
Re: EPICS and CAN field bus Graham Waters
RE: EPICS and CAN field bus David Beauregard
Prev: Re: Inter-IOC link problems Ralph Lange
Next: Re: EPICS and CAN field bus Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Converting Archive info to SDDS David Dudley
