Edit cursor.cc. Change: case CURSOR_K_RUN: XDefineCursor( display, win, run ); curCursor = run; break; to case CURSOR_K_RUN: XDefineCursor( display, win, willSet ); curCursor = willSet; break; Another point with edm concerns the –one or –server command line options. I tried them in several ways, but each time I run a new “edm –x …” I have a new edm main panel (“File View Path Help”) which is raised which causes some confusion. Is there a way to avoid this? -server means "send a msg to another edm process and tell it to open a main window for you" it does not mean "don't open a main window". -one is special and requires that all participating sessions use the same command line params except -display; it also sends a msg to another edm process and tells it to open a main window for you but if one has already been opened it simply raises the current main window (which is of course always somewhat dependent on the Xserver configuration and mood). Both options do open a main window by design. J.F. Gournay
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
