On 1/12/09 3:24 PM, Timothy Madden wrote:
> Folks
> The module, seq, will not build with EPICS-3.14.10. The same is true
> with sscan. There is some change in the source code that is
> incompatible. I think the file sscanRecord.c has a problem. I don't
> know which file has bad in sscan. They do build with 3.14.8.2.
> Tim
Hi, Tim.
What is your environment? What is the error you're getting?
Are you using seq 2.0.12? This version or later is required for EPICS
base 3.14.10 according to (see near the bottom of the page)
http://www.aps.anl.gov/epics/base/R3-14/10.php
As for the sscan module, have you seen this Tech-Talk thread
http://www.aps.anl.gov/epics/tech-talk/2008/msg01293.php
If you're trying to build synApps 5.3, you may find other modules that
don't build also. I ended up having to build from a synApps CVS
snapshot, but I can't deploy production systems against this.
It would be great if a new release of synApps could be made that would
work w/ EPICS base 3.14.10. Tim Mooney, is this in the works, do you
have an idea of when this might happen?
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT/CARS
- Re: area Detector on cygwin, win32-x86 Tim Mooney
- area Detector on cygwin, win32-x86 Timothy Madden
Re: area Detector on cygwin, win32-x86 Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
