Lewis, Yes, synApps 5.4 is intended to build against 3.14.10, and
has been in the works for months. I have docs, notes, and tentative
tags for almost everything, but I haven't run the package as a whole
past the other developers yet.
Tim
J. Lewis Muir wrote:
On 1/12/09 3:24 PM, Timothy Madden wrote:
Folks
The module, seq, will not build with EPICS-3.14.10. The same is true
with sscan. There is some change in the source code that is
incompatible. I think the file sscanRecord.c has a problem. I don't
know which file has bad in sscan. They do build with 3.14.8.2.
Tim
Hi, Tim.
What is your environment? What is the error you're getting?
Are you using seq 2.0.12? This version or later is required for EPICS
base 3.14.10 according to (see near the bottom of the page)
http://www.aps.anl.gov/epics/base/R3-14/10.php
As for the sscan module, have you seen this Tech-Talk thread
http://www.aps.anl.gov/epics/tech-talk/2008/msg01293.php
If you're trying to build synApps 5.3, you may find other modules that
don't build also. I ended up having to build from a synApps CVS
snapshot, but I can't deploy production systems against this.
It would be great if a new release of synApps could be made that would
work w/ EPICS base 3.14.10. Tim Mooney, is this in the works, do you
have an idea of when this might happen?
Lewis
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- area Detector on cygwin, win32-x86 Timothy Madden
- Re: area Detector on cygwin, win32-x86 J. Lewis Muir
Newport ESP300 on Linux Patrick Thomas
EPICS asyn error message Richard Pastrick
<2009>
2025
2026
Re: area Detector on cygwin, win32-x86 Andrew Johnson
<2009>
2025
2026
