Hi Tim,
On Monday 12 January 2009 15:24:15 Timothy Madden wrote:
> The module, seq, will not build with EPICS-3.14.10. The same is true
> with sscan. There is some change in the source code that is
> incompatible. I think the file sscanRecord.c has a problem. I don't
> know which file has bad in sscan. They do build with 3.14.8.2.
Are you building the right versions of those modules? You do have to use the
latest version of the sequencer (2.0.12), as mentioned on the R3.14.10
webpage. I'm pretty sure that Mark Rivers and various members of the BCDA
group have by now built most of synApps against R3.14.10, so there must by
now be newer versions of the relevent applications around somewhere.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- area Detector on cygwin, win32-x86 Timothy Madden
Re: area Detector on cygwin, win32-x86 J. Lewis Muir
Vdct and autosave's info field Alarcon, Arturo
<2009>
2025
2026
Re: area Detector on cygwin, win32-x86 Tim Mooney
<2009>
2025
2026
