Hi all,
I am trying to set up a few motors on a PMAC system with ethernet connection. I
have never worked with PMAC before and need some help.
I tried the tpmac package but I do not understand completely what I have to
write in the startup script and how set up the motor records. I need access to
13 motors with the numbers 1,2,3,4,5,7,8,9,10,11,17,18,19.
Can someone send me an example startup script and an example motor record, please?
So far, I guessed from various bits of documentation:
drvAsynIPPortConfigure pmac xx.xx.xx.xx:1025
pmacAsynIPPortConfigure pmac 0
pmacAsynMotorCreate pmac 0 0 19
drvAsynMotorConfigure pmacmotor pmacAsynMotor 0 20
After pmacAsynMotorCreate, I get error messages like these:
Creating PMAC motor driver on port pmac, address 0: card: 0, naxes: 19
2009/01/13 10:06:18.004 pmac read pmacFlush failed - thisRead=0, eomReason=0,
status=1
2009/01/13 10:06:18.666 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:18.882 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:19.182 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:25.801 Read/write error to PMAC card 0, axis 9
command I900=1. Status=1, Error=192.6.94.5:1025 timeout: Resource temporarily
unavailable
2009/01/13 10:06:26.117 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:26.317 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:26.910 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:27.127 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:27.427 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:34.050 Read/write error to PMAC card 0, axis
14 command I1400=1. Status=1, Error=192.6.94.5:1025 timeout: Resource
temporarily unavailable
2009/01/13 10:06:34.367 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:34.567 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:36.050 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:36.270 drvPmacGetAxisInitialStatus: not all
status values returned
2009/01/13 10:06:42.269 pmac read pmacFlush failed - thisRead=0, eomReason=0,
status=1
2009/01/13 10:06:42.370 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:42.570 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:42.870 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:43.270 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:43.770 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:50.523 pmac read pmacFlush failed -
thisRead=0, eomReason=0, status=1
2009/01/13 10:06:50.624 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:50.824 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:51.124 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:51.526 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:52.028 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:52.751 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:53.452 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:54.252 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:55.153 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:56.153 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:57.153 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:58.153 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:59.153 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:05.694 pmac read pmacFlush failed -
2009/01/13 10:07:05.794 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:05.994 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:06.294 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:06.694 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:07.194 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:07.794 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:08.494 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:09.294 pmac read pmacReadReady failed
status=1,retval=0
With only drvAsynIPPortConfigure and pmacAsynIPPortConfigure, I can get access
to the asynOctet layer and get responses to strings like "M9", but only
sometimes. Often, stopping the ioc brings the PMAC in a state where it does not
respond any more. Only a power cycle of the PMAC help. Any idea what is wrong?
Some more questions:
Can the motor record read the encoder values from PMAC?
How can I use programs (homing an scanning procedures) on the PMAC?
How to access other values (analog and binary IO) on the PMAC?
Thanks in advance for any help
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- RE: PMAC IP and motor records Rees, NP (Nick)
RE: EPICS asyn error message Rees, NP (Nick)
webca can't connect to pvs? Silver
<2009>
2025
2026
RE: EPICS asyn error message Richard Pastrick
<2009>
2025
2026
