hi,
I want to use webca. After compiling the code and copy .so file to mozilla's plugin directory. I use firefox to open the test.html coming with webca package. seems the plugin works, while I can't get the pv's value.
Ps, I can use caget to acqure the ai001's value first, then start the firefox from the shell to visit that test.html file.
Any help is appreciated. thanks a lot.
following is the webpage's context:
EPICS Channel Access Plug-in Test
This page contains a test case which test the implementation of EPICS Channel Access Plug-in Test
Test Result
Get EPICSPlugin scriptable instance PASSED
EPICSPlugin.version PASSED
EPICSPlugin.epicsVersion PASSED
Connection monitoring (unknown)
Connection monitoring (second) (unknown)
Connection monitoring (on connected) (unknown)
Connection monitoring (non-existant record) PASSED
Connection monitoring (second, non-existant record) PASSED
Get request (no blocking test) PASSED
- value (unknown)
- status (unknown)
- severity (unknown)
- timestamp (unknown)
Get string (enum) scalar (unknown)
Get double array (unknown)
Get long array (unknown)
Get string array (unknown)
Put request (no blocking test) PASSED
Put double scalar (unknown)
Put long scalar (unknown)
Put string (enum) scalar (unknown)
Put double array (unknown)
Put long array (unknown)
Put string array (unknown)
Put without callback PASSED
Put with wrong data (unknown)
Monitor request (no blocking test) PASSED
- value (unknown)
- status (unknown)
Monitor array (unknown)
Monitor destruction (unknown)
Best regards
Geyang 2009-01-13
- Re: webca can't connect to pvs? Tom Pelaia
- RE: webca can't connect to pvs? Purcell, J. David
PMAC IP and motor records Dirk Zimoch
RE: PMAC IP and motor records Rees, NP (Nick)
<2009>
2025
2026
Re: PMAC IP and motor records Dirk Zimoch
<2009>
2025
2026
