1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PMAC IP and motor records
To: "Rees, NP (Nick)" <[email protected]>
Date: Tue, 13 Jan 2009 15:16:51 +0100
PS: Not only restarting the IOC hangs up the system. Reading repeatedly does the same:
while true; do caput X06SA-PMAC:debug ver; sleep 0.1; done
X06SA-PMAC:debug "1.938  "
X06SA-PMAC:debug "938  "
X06SA-PMAC:debug "ver" (SEVR:INVALID STAT:TIMEOUT)
Errors on the ioc:
2009/01/13 15:14:11.471 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:11.849 pmac read pmacFlush failed - thisRead=0, eomReason=0, status=1 2009/01/13 15:14:11.950 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:12.150 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:12.450 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:12.850 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:13.350 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:13.950 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:13.950 pmac X06SA-PMAC:debug: No reply from device within 1000 ms 2009/01/13 15:14:14.213 pmac read pmacFlush failed - thisRead=0, eomReason=0, status=1 2009/01/13 15:14:14.314 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:14.514 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:14.814 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:15.214 pmac read pmacReadReady failed status=1,retval=02009/01/13 15:14:15.716 pmac read pmacReadReady failed status=1,retval=0
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
PMAC IP and motor records Dirk Zimoch
RE: PMAC IP and motor records Rees, NP (Nick)
Prev: Re: PMAC IP and motor records Dirk Zimoch
Next: RE: MAXvSetup is an undefined symbol Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PMAC IP and motor records Krzysztof Lazarski
Next: webca can't connect to pvs? Silver
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
