Hi Nick,
The PMAC says its version is 1.938. The controller is a Turbo PMAC2. The
connection uses TCP.
The PMAC is part of a "turn key" system which came with a Windows program. But
the program is not flexible enough. Thus, our users asked me to replace the
Windows computer with an EPICS ioc. I have not configured the PMAC and cannot
change the configuration. I can only reverse-engineer the system from what I
found in the source code of the Windows program and from spying on the network
traffic.
In particular I found in the configuration, that for any motor number n, the
encoder can be read with M210+n. For example for motor 1 read M211. I do not now
if that is typical for PMAC or special to this application.
Where can I learn the communication protocol, for example, what "M211" actually
means or does? I found many documents on the delta tau pages but which one
should I read a beginner? At the moment all your talking about Q and P
variables, and coordinate systems does not mean much to me.
I also have the problem that if I open and close a TCP socked to the PMAC a few
times, the PMAC hangs up and needs a power cycle. Have you ever seen such an
effect? On the other hand, restarting the Windows program does not show this effect.
Dirk
Rees, NP (Nick) wrote:
Dirk,
Gosh, suddenly everyone wants to know about the PMAC.
As far as I can tell, you have configured your pmac correctly - in fact
better than the example I gave in the earlier response to Richard
Pastrick because the last parameter in drvAsynMotorConfigure should be
one more than the last parameter in pmacAsynMotorCreate (because of a
1-based and 0-based numbering conflict).
What seems to be happening is the first error message you get is a
timeout when sending a VR_PMAC_FLUSH command to the PMAC. This is what
pmacFlush does in the interpose layer. I can't explain this unless you
have a old version of the PMAC firmware which doesn't support all the
current functionality. Please let me know what the "ver" command returns
and what type of PMAC you are trying to control. This is my best guess
as to the problem. I assume you have it running TCP as discussed in the
last thread on this back in December.
In answer to your other questions:
Can the motor record read the encoder values from PMAC?
The motor record has the current profiled demand position in RMP and the
encoder value in REP. What is meant by "encoder value" depends on how
you have configured the PMAC.
How can I use programs (homing an scanning procedures) on the PMAC?
You have full access to all PMAC functionality via the asynOctet port.
At DLS, we also have a set of interface guidelines to interface motion
programs so everything is standardised, and if you abide by these
guidelines, then we also have a pmacAsynCoord driver to connect
coordinate system axes to motor records. The specific pmacAsynCoord
driver requirements are:
- Q71..79 are reserved for the axis demand positions, and are set by
the EPICS software
- A position reporting PLC must be implemented which reports back the
positions of co-ordinate system axes A,B,C,U,V,W,X,Y,Z on variables
Q81..89
- The axis deadbands must be reported on variables Q91..Q99
- A standard motion program to move the co-ordinate system axes must
also be implemented
- If motor resolution and offset parameters need to be incorporated,
they should be defined in the variables P1xx and P3xx respectively (xx
represents the axis number)
How to access other values (analog and binary IO) on the PMAC?
These are accessed directly through the asynOctet port. Unfortunately,
it seems that streamDevice and asynMotor drivers conflict and end up in
a deadlock, so currently we use asynRecord and scalc to do the parsing.
We suspect that if we change asynMotor to use FIFO's for the status
callbacks (like Mark modified all the standard asyn types to do last
year) then the deadlock will go away, but we haven't checked this.
My corrected example fo Richard Pastrick for a 4 axis PMAC you should
do:
Configure the standard Ethernet asynIPPort
drvAsynIPPortConfigure("pmac1E", "172.23.86.84:1025", 0, 0, 0)
# Create the interpose layer on this port to properly handle the PMAC
protocol
pmacAsynIPPortConfigure("pmac1E", 0)
# Create a pmacAsynMotor driver connected tto this port
pmacAsynMotorCreate("pmac1E", 0, 0, 4)
# Setup the asynMotor layer (note the last parameter has to be one more
than the number of axes you specified in pmacAsynMotorCreate).
# Note the new asynPort name.
# There will be a warning at this stage about not being able to create
axis 0 - you should ignore this.
drvAsynMotorConfigure("pmac1", "pmacAsynMotor", 0, 5)
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: 13 January 2009 09:19
To: tech-talk
Subject: PMAC IP and motor records
Hi all,
I am trying to set up a few motors on a PMAC system with
ethernet connection. I
have never worked with PMAC before and need some help.
I tried the tpmac package but I do not understand completely
what I have to
write in the startup script and how set up the motor records.
I need access to
13 motors with the numbers 1,2,3,4,5,7,8,9,10,11,17,18,19.
Can someone send me an example startup script and an example
motor record, please?
So far, I guessed from various bits of documentation:
drvAsynIPPortConfigure pmac xx.xx.xx.xx:1025
pmacAsynIPPortConfigure pmac 0
pmacAsynMotorCreate pmac 0 0 19
drvAsynMotorConfigure pmacmotor pmacAsynMotor 0 20
After pmacAsynMotorCreate, I get error messages like these:
Creating PMAC motor driver on port pmac, address 0: card: 0, naxes: 19
2009/01/13 10:06:18.004 pmac read pmacFlush failed -
thisRead=0, eomReason=0,
status=1
2009/01/13 10:06:18.666 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:18.882 pmac read
status=1,retval=02009/01/13 10:06:19.182 pmac read
status=1,retval=02009/01/13 10:06:25.801 Read/write error to
PMAC card 0, axis 9
command I900=1. Status=1, Error=192.6.94.5:1025 timeout:
Resource temporarily
unavailable
2009/01/13 10:06:26.117 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:26.317 pmac read
status=1,retval=02009/01/13 10:06:26.910 pmac read
status=1,retval=02009/01/13 10:06:27.127 pmac read
status=1,retval=02009/01/13 10:06:27.427 pmac read
status=1,retval=02009/01/13 10:06:34.050 Read/write error to
PMAC card 0, axis
14 command I1400=1. Status=1, Error=192.6.94.5:1025 timeout: Resource
temporarily unavailable
2009/01/13 10:06:34.367 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:34.567 pmac read
status=1,retval=02009/01/13 10:06:36.050 pmac read
status=1,retval=02009/01/13 10:06:36.270
drvPmacGetAxisInitialStatus: not all
status values returned
2009/01/13 10:06:42.269 pmac read pmacFlush failed -
status=1
2009/01/13 10:06:42.370 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:42.570 pmac read
status=1,retval=02009/01/13 10:06:42.870 pmac read
status=1,retval=02009/01/13 10:06:43.270 pmac read
status=1,retval=02009/01/13 10:06:43.770 pmac read
status=1,retval=02009/01/13 10:06:50.523 pmac read pmacFlush failed -
thisRead=0, eomReason=0, status=1
2009/01/13 10:06:50.624 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:06:50.824 pmac read
status=1,retval=02009/01/13 10:06:51.124 pmac read
status=1,retval=02009/01/13 10:06:51.526 pmac read
status=1,retval=02009/01/13 10:06:52.028 pmac read
status=1,retval=02009/01/13 10:06:52.751 pmac read
status=1,retval=02009/01/13 10:06:53.452 pmac read
status=1,retval=02009/01/13 10:06:54.252 pmac read
status=1,retval=02009/01/13 10:06:55.153 pmac read
status=1,retval=02009/01/13 10:06:56.153 pmac read
status=1,retval=02009/01/13 10:06:57.153 pmac read
status=1,retval=02009/01/13 10:06:58.153 pmac read
status=1,retval=02009/01/13 10:06:59.153 pmac read
status=1,retval=02009/01/13 10:07:05.694 pmac read pmacFlush failed -
2009/01/13 10:07:05.794 pmac read pmacReadReady failed
status=1,retval=02009/01/13 10:07:05.994 pmac read
status=1,retval=02009/01/13 10:07:06.294 pmac read
status=1,retval=02009/01/13 10:07:06.694 pmac read
status=1,retval=02009/01/13 10:07:07.194 pmac read
status=1,retval=02009/01/13 10:07:07.794 pmac read
status=1,retval=02009/01/13 10:07:08.494 pmac read
status=1,retval=02009/01/13 10:07:09.294 pmac read
status=1,retval=0
With only drvAsynIPPortConfigure and pmacAsynIPPortConfigure,
I can get access
to the asynOctet layer and get responses to strings like
"M9", but only
sometimes. Often, stopping the ioc brings the PMAC in a state
where it does not
respond any more. Only a power cycle of the PMAC help. Any
idea what is wrong?
Some more questions:
Thanks in advance for any help
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Dr. Dirk Zimoch
- RE: PMAC IP and motor records Rees, NP (Nick)
- PMAC IP and motor records Dirk Zimoch
RE: webca can't connect to pvs? Purcell, J. David
Re: PMAC IP and motor records Dirk Zimoch
<2009>
2025
2026
<2009>
2025
2026
