That test.html file doesn't work for me, either. CAML 2.0 will be
released very soon and offers much more powerful features. I recommend
waiting for it. However, if you want to test WebCA with real PVs, I've
written a simple probe page in which you can specify a PV and it will
display some useful information about it in addition to live
monitoring. It demonstrates the basics of WebCA. Let me know whether
that works for you.
CAML 2.0 will allow you to simply specify rich controls and lay them
out within HTML. You don't have to write any JavaScript (unless you
really want to).
best regards,
tom
probe.js
Description: JavaScript source
Title: CA Probe
CA Probe
PV: Unspecified
| Value | Count | Status | Severity | Timestamp |
| Limits | Lower | Upper |
| Alarm | | |
| Warning | | |
| Operation | | |
| Control | | |
On Jan 13, 2009, at 4:34 AM, Silver wrote:
hi,
I want to use webca. After compiling the code and copy .so file to
mozilla's plugin directory. I use firefox to open the test.html
coming with webca package. seems the plugin works, while I can't get
the pv's value.
Ps, I can use caget to acqure the ai001's value first, then start
the firefox from the shell to visit that test.html file.
Any help is appreciated. thanks a lot.
following is the webpage's context:
EPICS Channel Access Plug-in Test
This page contains a test case which test the implementation of
Test Result
Get EPICSPlugin scriptable instance PASSED
EPICSPlugin.version PASSED
EPICSPlugin.epicsVersion PASSED
Connection monitoring (unknown)
Connection monitoring (second) (unknown)
Connection monitoring (on connected) (unknown)
Connection monitoring (non-existant record) PASSED
Connection monitoring (second, non-existant record) PASSED
Get request (no blocking test) PASSED
- value (unknown)
- status (unknown)
- severity (unknown)
- timestamp (unknown)
Get string (enum) scalar (unknown)
Get double array (unknown)
Get long array (unknown)
Get string array (unknown)
Put request (no blocking test) PASSED
Put double scalar (unknown)
Put long scalar (unknown)
Put string (enum) scalar (unknown)
Put double array (unknown)
Put long array (unknown)
Put string array (unknown)
Put without callback PASSED
Put with wrong data (unknown)
Monitor request (no blocking test) PASSED
- value (unknown)
- status (unknown)
Monitor array (unknown)
Monitor destruction (unknown)
Best regards
Geyang 2009-01-13
- Re: webca can't connect to pvs? Andrew Johnson
- webca can't connect to pvs? Silver
RE: PMAC IP and motor records Rees, NP (Nick)
RE: webca can't connect to pvs? Purcell, J. David
<2009>
2025
2026
<2009>
2025
2026
