Actually I use Linux, Windows and Cygwin IOCs in addition to vxWorks. I have never had a problem with the transform record on any of these platforms, and others report no problems on RTEMS. I agree that the dfanout can be used instead of the transform in this particular application, but there are many applications where this is not true, the transform record provides unique capabilities.
Thus, if you are convinced that you have found a bug in the transform record it would be most helpful if you could track it down. Of course it is possible that the bug is elsewhere in your application and the use of the transform record just happens to expose it.
Martk
Sent: Tue 1/13/2009 12:49 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: stop all motors
Mark Rivers wrote:
> Can you figure out why the transform record is causing the crash? It is widely used with no other problems that I know of.
You use vxWorks. We use RTEMS.
A generic record such as "dfanout" works very well for the purpose.
In fact, I do not think a custom record such as a "transform" record is
needed.
Kate
> Mark
> ________________________________
> From: [email protected] on behalf of Kate Feng
> Sent: Tue 1/13/2009 11:00 AM
> To: [email protected]
> Subject: stop all motors
> Hi,
> If the "all_com_32.db" is loaded in the database, it triggered system
> crash while we were running one of our RTEMS applications.
> I traced down that the bugs were caused by the "transform" record
> (e.g. transformRecord.c) for the motor "allstop" function. However,
> a generic record "dfanout" can replace it to function correctly.
> The attached all_com_32.db is what I used to solve the problem.
> It seems to work so far.
> Regards,
> Kate
> #Kate Feng 12/30/2008:Use "dfanout" instead of "transform" for motor
> "allstop"
> grecord(bo,"$(P)allstop") {
> field(DOL,"1")
> field(OUT,"$(P)allstop1.VAL PP MS")
> grecord(bo,"$(P)gateOpen") {
> field(ZNAM,"Closed")
> field(ONAM,"Open")
> grecord(calc,"$(P)alldoneBlinker") {
> field(SCAN,".5 second")
> field(CALC,"B?0:!A")
> field(INPA,"$(P)alldoneBlinker.VAL NPP NMS")
> field(INPB,"$(P)alldone.VAL NPP NMS")
> grecord(dfanout,"$(P)allstop5") {
> field(DESC,"allstop distribution")
> field(OMSL,"closed_loop")
> field(DOL,"1")
> field(OUTA,"$(P)m25.STOP CA MS")
> field(OUTB,"$(P)m26.STOP CA MS")
> field(OUTC,"$(P)m27.STOP CA MS")
> field(OUTD,"$(P)m28.STOP CA MS")
> field(OUTE,"$(P)m29.STOP CA MS")
> field(OUTF,"$(P)m30.STOP CA MS")
> field(OUTG,"$(P)m31.STOP CA MS")
> field(OUTH,"$(P)m32.STOP CA MS")
> grecord(dfanout,"$(P)allstop4") {
> field(DOL,"1")
> field(OUTA,"$(P)m17.STOP CA MS")
> field(OUTB,"$(P)m18.STOP CA MS")
> field(OUTC,"$(P)m19.STOP CA MS")
> field(OUTD,"$(P)m20.STOP CA MS")
> field(OUTE,"$(P)m21.STOP CA MS")
> field(OUTF,"$(P)m22.STOP CA MS")
> field(OUTG,"$(P)m23.STOP CA MS")
> field(OUTH,"$(P)m24.STOP CA MS")
> grecord(dfanout,"$(P)allstop3") {
> field(DOL,"1")
> field(OUTA,"$(P)m9.STOP CA MS")
> field(OUTB,"$(P)m10.STOP CA MS")
> field(OUTC,"$(P)m11.STOP CA MS")
> field(OUTD,"$(P)m12.STOP CA MS")
> field(OUTE,"$(P)m13.STOP CA MS")
> field(OUTF,"$(P)m14.STOP CA MS")
> field(OUTG,"$(P)m15.STOP CA MS")
> field(OUTH,"$(P)m16.STOP CA MS")
> grecord(dfanout,"$(P)allstop2") {
> field(DOL,"1")
> field(OUTA,"$(P)m1.STOP CA MS")
> field(OUTB,"$(P)m2.STOP CA MS")
> field(OUTC,"$(P)m3.STOP CA MS")
> field(OUTD,"$(P)m4.STOP CA MS")
> field(OUTE,"$(P)m5.STOP CA MS")
> field(OUTF,"$(P)m6.STOP CA MS")
> field(OUTG,"$(P)m7.STOP CA MS")
> field(OUTH,"$(P)m8.STOP CA MS")
> grecord(dfanout,"$(P)allstop1") {
> field(DOL,"1")
> field(OUTA,"$(P)AbortScans.PROC PP MS")
> field(OUTB,"$(P)allstop2.VAL PP MS")
> field(OUTC,"$(P)allstop3.VAL PP MS")
> field(OUTD,"$(P)allstop4.VAL PP MS")
> field(OUTE,"$(P)allstop5.VAL PP MS")
> grecord(swait,"$(P)alldone") {
> field(DESC,"All motors done moving")
> field(SCAN,"I/O Intr")
> field(PINI,"YES")
> field(INAN,"$(P)alldone_1.VAL")
> field(INBN,"$(P)alldone_2.VAL")
> field(INCN,"$(P)alldone_3.VAL")
> field(INDN,"$(P)alldone_4.VAL")
> field(ININ,"$(P)gateOpen.VAL")
> field(CALC,"A&&B&&C&&D&&!I")
> field(DOLD,"1")
> grecord(swait,"$(P)alldone_2") {
> field(DESC,"8 motors done moving")
> field(PINI,"YES")
> field(INAN,"$(P)m9.DMOV")
> field(INBN,"$(P)m10.DMOV")
> field(INCN,"$(P)m11.DMOV")
> field(INDN,"$(P)m12.DMOV")
> field(INEN,"$(P)m13.DMOV")
> field(INFN,"$(P)m14.DMOV")
> field(INGN,"$(P)m15.DMOV")
> field(INHN,"$(P)m16.DMOV")
> field(CALC,"(a&b&c&d&e&f&g&h)=1")
> field(OOPT,"Transition To Non-zero")
> field(DOLD,"1")
> grecord(swait,"$(P)alldone_1") {
> field(PINI,"YES")
> field(INAN,"$(P)m1.DMOV")
> field(INBN,"$(P)m2.DMOV")
> field(INCN,"$(P)m3.DMOV")
> field(INDN,"$(P)m4.DMOV")
> field(INEN,"$(P)m5.DMOV")
> field(INFN,"$(P)m6.DMOV")
> field(INGN,"$(P)m7.DMOV")
> field(INHN,"$(P)m8.DMOV")
> field(DOLD,"1")
> grecord(swait,"$(P)alldone_3") {
> field(PINI,"YES")
> field(INAN,"$(P)m17.DMOV")
> field(INBN,"$(P)m18.DMOV")
> field(INCN,"$(P)m19.DMOV")
> field(INDN,"$(P)m20.DMOV")
> field(INEN,"$(P)m21.DMOV")
> field(INFN,"$(P)m22.DMOV")
> field(INGN,"$(P)m23.DMOV")
> field(INHN,"$(P)m24.DMOV")
> field(DOLD,"1")
> grecord(swait,"$(P)alldone_4") {
> field(PINI,"YES")
> field(INAN,"$(P)m25.DMOV")
> field(INBN,"$(P)m26.DMOV")
> field(INCN,"$(P)m27.DMOV")
> field(INDN,"$(P)m28.DMOV")
> field(INEN,"$(P)m29.DMOV")
> field(INFN,"$(P)m30.DMOV")
> field(INGN,"$(P)m31.DMOV")
> field(INHN,"$(P)m32.DMOV")
> field(DOLD,"1")
> grecord(swait,"$(P)alldoneBlink") {
> field(INAN,"$(P)alldone")
> field(INBN,"$(P)alldoneBlinker")
> field(CALC,"a?0:b")
- Re: stop all motors Kate Feng
- stop all motors Kate Feng
- RE: stop all motors Mark Rivers
Re: stop all motors Tim Mooney
Re: PMAC IP and motor records Krzysztof Lazarski
<2009>
2025
2026
<2009>
2025
2026
