1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MM4000 asynMotor problem
To: "Pearson, MR (Matthew)" <[email protected]>, "epics" <[email protected]>, "Mark Rivers" <[email protected]>, "Ronald L. Sluiter" <[email protected]>
Date: Fri, 13 Mar 2009 15:39:11 +0100
Thanks to all your replies. I'd reply once here.
> Was the final position reached? Or did the motor stop just outside the
deadband RDBD?
Yes. The actual position is reached.
> Are you able to do another move after you 'prod' the record?
Yes. It can still drive the motor to the correct position.
> Does this happen every time on the same axes, or intermittently?
Every time with the same axes.
>To help diagnose this it might be worth turning on Asyn tracing for
that
>axis, like:
>asynSetTraceIOMask("PORTNAME",{card_no},255)
>asynSetTraceMask("PORTNAME",{card_no},255)
I have redirect the output to file. From there I can say the
communication is correct.
MS and TP command return correct information.
>Might be worth updating to asynMotor from 6-4-2 as well.
This is also what Ron has suggested.
I will try first use the new release. But because the way how drivers
are used in SLS,
it requires some time to setup. I will get back to you then.
Thanks all.
Xiaoqiang
RE: MM4000 asynMotor problem Wang Xiaoqiang
RE: MM4000 asynMotor problem Pearson, MR (Matthew)
Prev: RE: MM4000 asynMotor problem Pearson, MR (Matthew)
Next: RE: MM4000 asynMotor problem Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
