1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MM4000 asynMotor problem
To: "Pearson, MR (Matthew)" <[email protected]>, "epics" <[email protected]>, "Mark Rivers" <[email protected]>, "Ronald L. Sluiter" <[email protected]>
Date: Fri, 13 Mar 2009 16:53:10 +0100
Hi again,
I quickly made a setup running motor 6-4-2 release. The problem is still
there.
But I seem to get a little clue.
I have 3 three such controllers and two works just fine. With the well
functioned
controller, when one axis is reported as "motor in moton", I try to move
any
other axis and this axis will end up with MIP=0x420 and DMOV is never
reset.
On the problemic controller, the first axis' MSTA field is 0xa0a when
idling.
According to the motor doc, it means "PROBLEM: driver stopped polling".
(Which is
not true, because it can be moved and position is reported correctly and
even DMOV field.)
Would this false status report affect the other axis?
How do I know why the first axis is reported as "PROBLEM", while the
polling is correct.
Where should I put diagnostic messages?
Thanks.
Xiaoqiang
Re: MM4000 asynMotor problem J. Lewis Muir
MM4000 asynMotor problem Wang Xiaoqiang
RE: MM4000 asynMotor problem Pearson, MR (Matthew)
RE: MM4000 asynMotor problem Wang Xiaoqiang
Prev: RE: MM4000 asynMotor problem Wang Xiaoqiang
Next: Re: MM4000 asynMotor problem J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
