1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MM4000 asynMotor problem
To: Wang Xiaoqiang <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 13 Mar 2009 13:24:42 -0400
On 3/13/09 11:53 AM, Wang Xiaoqiang wrote:
> Hi again,
> I quickly made a setup running motor 6-4-2 release. The problem is still
> there.
> But I seem to get a little clue.
> I have 3 three such controllers and two works just fine. With the well
> functioned
> controller, when one axis is reported as "motor in moton", I try to move
> any
> other axis and this axis will end up with MIP=0x420 and DMOV is never
> reset.
> On the problemic controller, the first axis' MSTA field is 0xa0a when
> idling.
> According to the motor doc, it means "PROBLEM: driver stopped polling".
> (Which is
> not true, because it can be moved and position is reported correctly and
> even DMOV field.)
> Would this false status report affect the other axis?
> How do I know why the first axis is reported as "PROBLEM", while the
> polling is correct.
> Where should I put diagnostic messages?
> Thanks.
Hi, Xiaoqiang.
Are the firmware versions of the three controllers the same?
I had a problem a while back with the Mclennan PM304 motor module driver
where it wasn't working right.  The problem turned out to be that the
status bits from the controller had different meanings for different
firmware versions (motorApp/MclennanSrc/drvPM304.cc).
Lewis
RE: MM4000 asynMotor problem Wang Xiaoqiang
RE: MM4000 asynMotor problem Pearson, MR (Matthew)
Prev: RE: MM4000 asynMotor problem Wang Xiaoqiang
Next: [Fwd: Re: MM4000 asynMotor problem] Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: MM4000 asynMotor problem Wang Xiaoqiang
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
