1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MM4000 asynMotor problem
To: "J. Lewis Muir" <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 13 Mar 2009 23:50:53 +0100
Thanks Lewis.
The version strings are the same "MM4006X Controller Version 6.03b date
02-18-2002"
Also the MSTA field is false only for the first axis of that controller.
Xiaoqiang
-----Original Message-----
Sent: Friday, March 13, 2009 6:25 PM
To: Wang Xiaoqiang
Cc: Pearson, MR (Matthew); epics; Mark Rivers; Ronald L. Sluiter
Subject: Re: MM4000 asynMotor problem
On 3/13/09 11:53 AM, Wang Xiaoqiang wrote:
> Hi again,
> I quickly made a setup running motor 6-4-2 release. The problem is
> still there.
> But I seem to get a little clue.
> I have 3 three such controllers and two works just fine. With the well
> functioned controller, when one axis is reported as "motor in moton",
> I try to move any other axis and this axis will end up with MIP=0x420
> and DMOV is never reset.
> On the problemic controller, the first axis' MSTA field is 0xa0a when
> idling.
> According to the motor doc, it means "PROBLEM: driver stopped
polling".
> (Which is
> not true, because it can be moved and position is reported correctly
> and even DMOV field.) Would this false status report affect the other
> axis?
> How do I know why the first axis is reported as "PROBLEM", while the
> polling is correct.
> Where should I put diagnostic messages?
> Thanks.
Hi, Xiaoqiang.
Are the firmware versions of the three controllers the same?
I had a problem a while back with the Mclennan PM304 motor module driver
where it wasn't working right.  The problem turned out to be that the
status bits from the controller had different meanings for different
firmware versions (motorApp/MclennanSrc/drvPM304.cc).
Lewis
MM4000 asynMotor problem Wang Xiaoqiang
RE: MM4000 asynMotor problem Pearson, MR (Matthew)
RE: MM4000 asynMotor problem Wang Xiaoqiang
Re: MM4000 asynMotor problem J. Lewis Muir
Prev: RE: Difficulty with edm installation Kevin Anderson
Next: Re: Looking for feedback on what epics users require Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MM4000 asynMotor problem J. Lewis Muir
Next: [Fwd: Re: MM4000 asynMotor problem] Ron Sluiter
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
