1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: connections with pasynOctetSyncIO->connect
Cc: Tech Tech Talk <[email protected]>
Date: Tue, 31 Mar 2009 19:41:12 -0500
I should also mention the specs of the non functioning system:
vxWorks 5.5.2
synApps 5.4 which gives motor 6.4.2 and asyn 4-10
mvme2100
John
John Hammonds wrote:
The information in previous messages was for a vxWorks IOC. I have now tried this on a Linux softIOC and this seems to work fine. This is for the Aerotech Ensemble which is now in the motor package included with synApps. Anyone have any ideas why this might work with Linux and not vxWorks?
John
Mark,
This connection is set up with the following commands:
drvAsynIPPortConfigure("usaxsEns","164.54.102.16:8000",0,0,0)
asynOctetSetInputEos("usaxsEns",0,"\n")
asynOctetSetOutputEos("usaxsEns",0,"\n")
asynSetTraceMask("usaxsEns",0,0x9)
asynSetTraceIOMask("usaxsEns",0,0x2)
I only see evidence of the first try for this send that tests communications. There should be 3 retries. After the first try we get the message:
164.54.102.16:8000 write error: S_errno_EPIPE
We then get the message that seems to come from pasynUser->errorMessage on subsequent retries.
I can go to an asynOctet MEDM screen and send some messages. The trace on these reflects the send/recieve of messages. I have to send a couple of messages to get the connect but communications can be a bit spotty (sometimes need retries).
I can also add the following to the st.cmd and see reasonable communications coming through:
asynOctetConnect("myID", "usaxsEns", 0, "\n", "\n", 80, 20)
asynOctetWriteRead("myID", "NONE")
asynOctetWriteRead("myID", "GETPARM(CONTROL, 265)")
asynOctetWriteRead("myID", "GETPARM(@0, 257")
asynOctetWriteRead("myID", "AXISSTATUS(@0)")
This seems much more reliable than the using the asynRecord Interface. I took this from an example on http://www.aps.anl.gov/epics/modules/soft/asyn/R4-10/asynDriver.html. Note however that the documentation for asynOctetConnect does not appear to match the example.
John
Mark Rivers wrote:
John,
I think that if it returns asynSuccess you should ignore the error message, because it may be stale. What do you see if you turn on asynTrace and do some writes? Does the driver claim to be writing? What type of communication port is this? Mark
Sent: Mon 3/30/2009 11:21 PM
To: Tech Tech Talk
Subject: connections with pasynOctetSyncIO->connect
What checks should be done to verify a connection with
pasynOctetSyncIO->connect? I have a driver that calls this. The return
value is asynSuccess but the pasynUser->errorMessage is "port usaxsEns
or addr -1 not connected" and we see no communication.
John
John Hammonds
Beamline Controls and Data Acquisition Group
APS Engineering Support Division
Argonne National Laboratory
[email protected] <mailto:[email protected]>
(630)252-5317
John Hammonds
(630)252-5317
RE: connections with pasynOctetSyncIO->connect Mark Rivers
connections with pasynOctetSyncIO->connect John Hammonds
Re: connections with pasynOctetSyncIO->connect John Hammonds
Prev: Re: connections with pasynOctetSyncIO->connect John Hammonds
Next: RE: connections with pasynOctetSyncIO->connect Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
