John,
I don't know what's wrong. I talk to the Newport XPS motor controller from vxWorks also over TCP/IP and it normally works fine. I do have a problem with every couple of weeks the sockets being disconnected, but otherwise it works reliably. Perhaps try increasing the timeouts? Have you played with that in the asynRecord?
Sent: Tue 3/31/2009 7:41 PM
To: Mark Rivers
Cc: Tech Tech Talk
Subject: Re: connections with pasynOctetSyncIO->connect
I should also mention the specs of the non functioning system:
vxWorks 5.5.2
synApps 5.4 which gives motor 6.4.2 and asyn 4-10
mvme2100
John
John Hammonds wrote:
> The information in previous messages was for a vxWorks IOC. I have
> now tried this on a Linux softIOC and this seems to work fine. This
> is for the Aerotech Ensemble which is now in the motor package
> included with synApps. Anyone have any ideas why this might work with
> Linux and not vxWorks?
> John
>> Mark,
>> This connection is set up with the following commands:
>> drvAsynIPPortConfigure("usaxsEns","164.54.102.16:8000",0,0,0)
>> asynOctetSetInputEos("usaxsEns",0,"\n")
>> asynOctetSetOutputEos("usaxsEns",0,"\n")
>> asynSetTraceMask("usaxsEns",0,0x9)
>> asynSetTraceIOMask("usaxsEns",0,0x2)
>> I only see evidence of the first try for this send that tests
>> communications. There should be 3 retries. After the first try we
>> get the message:
>> 164.54.102.16:8000 write error: S_errno_EPIPE
>> We then get the message that seems to come from
>> pasynUser->errorMessage on subsequent retries.
>> I can go to an asynOctet MEDM screen and send some messages. The
>> trace on these reflects the send/recieve of messages. I have to send
>> a couple of messages to get the connect but communications can be a
>> bit spotty (sometimes need retries).
>> I can also add the following to the st.cmd and see reasonable
>> communications coming through:
>> asynOctetConnect("myID", "usaxsEns", 0, "\n", "\n", 80, 20)
>> asynOctetWriteRead("myID", "NONE")
>> asynOctetWriteRead("myID", "GETPARM(CONTROL, 265)")
>> asynOctetWriteRead("myID", "GETPARM(@0, 257")
>> asynOctetWriteRead("myID", "AXISSTATUS(@0)")
>> This seems much more reliable than the using the asynRecord
>> Interface. I took this from an example on
>> http://www.aps.anl.gov/epics/modules/soft/asyn/R4-10/asynDriver.html.
>> Note however that the documentation for asynOctetConnect does not
>> appear to match the example.
>> John
>> Mark Rivers wrote:
>>> John,
>>> I think that if it returns asynSuccess you should ignore the error
>>> message, because it may be stale.
>>> What do you see if you turn on asynTrace and do some writes? Does
>>> the driver claim to be writing? What type of communication port is
>>> this?
>>> Mark
>>> ________________________________
>>> From: [email protected] on behalf of John Hammonds
>>> Sent: Mon 3/30/2009 11:21 PM
>>> To: Tech Tech Talk
>>> Subject: connections with pasynOctetSyncIO->connect
>>> What checks should be done to verify a connection with
>>> pasynOctetSyncIO->connect? I have a driver that calls this. The
>>> return
>>> value is asynSuccess but the pasynUser->errorMessage is "port usaxsEns
>>> or addr -1 not connected" and we see no communication.
>>> Thanks,
>>> John
>>> John Hammonds
>>> Beamline Controls and Data Acquisition Group
>>> APS Engineering Support Division
>>> Argonne National Laboratory
>>> [email protected] <mailto:[email protected]>
>>> (630)252-5317
John Hammonds
(630)252-5317
- devLib Davidsaver, Michael
- connections with pasynOctetSyncIO->connect John Hammonds
- RE: connections with pasynOctetSyncIO->connect Mark Rivers
- Re: connections with pasynOctetSyncIO->connect John Hammonds
CLS Openings in the Control and Instrumentation Group Elder Matias
<2009>
2025
2026
<2009>
2025
2026
